Leaking Injectors - 205
Results 1 to 2 of 2
    9,180
    Default Leaking Injectors - 205
    I got the 205 GTI running on the Megasquirt today.
    I had the tachymetric relay bridged out whilst I was setting up the parameters in the ECU. On going to start it the engine wouldn't turn over, two of the cylinders were full of petrol!
    Looks like new injectors needed.
    I had this problem after the Deni autocross a few weeks back and thought it might have been water leaking past the head gasket. It had given no trouble since then but I have been dreading having to fix it.
    I'm a bit happier about changing injectors than doing a head gasket change.
    Graham
    303
    Graham
    Did you actually get it running, if so how well. Is it an improvement over the Bosch setup?
    Jarrod
