Pug track car
Results 1 to 25 of 27
Thread: Pug track car
    Fellow Frogger! cam740's Avatar
    Apr 2005
    Southern Beaches SA
    867
    Icon5 Pug track car
    Not sure if it should be posted here or under motorsport but i thought here would be a good place to start!!!
    i'm thinking of buy a cheapish car (under $3k) to have as a "fun" car that could also see some (maybe 3 or 4 times a year as a guess) track action and I was thinking bout a Mi16.
    I know everyone will point me to a 205 but i just love the extra room of the 405 - what would i need to look out for and do to make it a safe fun track car that is still road usable!!
    I figure if anyones gonna have ideas on this it'll be you guys!!
    12,256
    it can be classed as technical/performance so i'll stick it in here for you
    1 x '98 306 GTi6
    Apr 2005
    Southern Beaches SA
    867
    cheers!!
    al
    al is offline
    1000+ Posts al's Avatar
    Dec 2004
    2,012
    Quote Originally Posted by cam740
    Bugger the 205 brigade... I'm tossing up buying another Mi16, stripping it out and having a crack at the motorsport thing.
    From the two goes i've had in my Mi16 on the track i think it was excellent, but my driving skills are limited and i don't think i did it justice. (I'm sure there are others here that can provide you with more extensive info about the cars abilities)
    As for picking one up for a few grand... I've seen a few advertised this year for $4 - 4.5, although i have no idea about their condition.
    Good luck anyway. Keep us posted.
    7,446
    An Mi16 track car is a great idea! You just need to throw away as much weight as possible. eg carpet, underlay, A/C, spare etc.
    You should also fit a closer ratio 205 GTi gearbox and an LSD, and you'd have a very nice starting package.
    I should elaborate more on the gearbox. The key is to keep the 16V on the boil and the Mi16 is a reasonably heavy car. The best combination is to use the 205 3rd, 4th and 5th ratios with Mi16 1st, 2nd and diff. You obviously don't need to do this first, but it's something to aim for.
    Member bj_dove's Avatar
    108
    my 405 mi16 project is aiming for a car that effective on the track, but also a mildly friendly road car, hopefully we can get a few more 405's on the track!
    PeterT, what is available for the Mi16 as far as LSD's go??
    cheers
    '91 Peugeot 405 Mi16 - only just run in......
    555
    Wouldn't the LSD's from 205's work exactly the same? If so, hook that shiz up wit a phat quaife numba an let rip biotch! I think they're somewhere in the region of $1400 and they rock, hard.
    1987 205 GTI - Graphite Grey - 206k km's
    1988 MR2 Supercharger - Mica Blue - 114k km's
    Apr 2005
    Southern Beaches SA
    867
    What sorta suspension mods need to be made to make it effective as a track tool - bearing inmind it'll still be on the road???
    And whats the best way of boosting the power a little??
    1000+ Posts tekkie's Avatar
    Jun 2002
    1,516
    suspension mods are the same as any other FWD car.
    front: Caster as much as you can physically achieve, camber, toe OUT
    plenty of wheel travel to achieve traction
    rear: As stiff as you can live with on the road, camber, toe IN, larger swaybar. Expect taily rear end.
    LSD is a must, keeping in mind the class limitations.
    Wheels: light, small diameter will give better gearing.
    Brakes: Dot4+ liquid, quality pads. Parry was singing praises of the DS3000's lately.
    and as Peter pointed out. anything that is dead weight is useless.
    Leave power alone until you have suspension sorted.
    Last edited by tekkie; 22nd April 2005 at 06:30 PM. Reason: toe in out confused ... corrected
    1000+ Posts pgti6's Avatar
    May 2001
    1,612
    If you intend to do any track work in an 1.9l Mi16, I think the first modification should be a baffled sump. A must especially for Phillip Islands' long sweepers.
    One problem you'll encounter with suspension mods is the lack of most things for the 405. Springs & dampers are available, but arb & torsion bars will need be made up.
    If you want to tweak the motor, see PeterT about one of his custom cams.
    The rest will depend your budget.
    Good luck-it would be great to see more 405's trackside.
    Jeff
    Lap times-
    Sandown 1 27.9
    Phillip Island 1 53.8
    Previous Frenchies-
    1988 205Gti
    1998 306 GTi6
    1997 306 N5 sedan
    1996 306 N3 XT hatch
    1000+ Posts U Turn's Avatar
    1,761
    Quote Originally Posted by tekkie
    toe in
    I've heard toe out at the front for fwd's helps the car turn in better. Certainly felt like it with my car.
    Take the long way home....
    - 306 gti6
    123
    Quote Originally Posted by U Turn
    Hang on you blokes, this bloke wants a "track car " for under $3000 !!!!! that might buy him the car but as we all know it only STARTS there !!. LSD $1400 + fitting, 205 gears + fitting, suspension maybe $1200 if he does it on the cheap, and thats without engine mods !!, $3000 ?????. I dont think so.
    Fellow Frogger! Andreas's Avatar
    Sep 2000
    1,200
    Quote Originally Posted by pgti6
    What he said!
    Jun 2002
    1,516
    OW CRAP !
    Front: toe OUT ofcourse !!!!!
    Rear: toe IN
    Apr 2005
    Southern Beaches SA
    867
    Quote Originally Posted by maxie
    I'm well aware that the overall costs are gonna be a lot more than $3k but that the initial outlay!!!
    Lets face it ANYTHINGS gonna be better around a track than an auto 740 turbo with stock suspension!!!! lol
    al
    al is offline
    Dec 2004
    2,012
    I've been looking into picking up something cheap to bash around autocrosses/ tracks etc today, and i reckon that something like a fuego could go ok.
    As much as i would like to use my current Mi16 i think that i would rather pick up a second car, something rougher that i would have to worry about less. Also, i noticed a couple of really cheap fuegos (under $1k) advertised...
    Anyone driven one of these in anger...? Would they provide a decent basis for a beginners track slag?
    Apr 2005
    Southern Beaches SA
    867
    Quote Originally Posted by al_
    Good point Al - maybe my question should be 'whats a cheap car that could be some fun on the track'???
    Lets face it if it's not as fast around a track as a WRX (have u guys seen the 2007 Sti pics??? ) it's all about the fun!!!
    9,175
    What's more fast doesn't look any good either! It is usually the slower cars that put on the best show, have a look at the 1960s racing 203 pictures posted recently.
    My most enjoyable rallies over the years have always been in bog standard 403s and 404s.
    Graham
    8,394
    Anyone driven one of these in anger...? Would they provide a decent basis for a beginners track slag?[/QUOTE]
    .....most of the time.Never done track, but they are tough as, pretty good in a prang, and cheap as chips. Mine was $700 with conis,big exhaust and breaks. and good exterior.
    Jo
    9,175
    Quote Originally Posted by jo proffi
    Jo[/QUOTE]
    One of what?
    Graham
    al
    al is offline
    Dec 2004
    2,012
    One of what?
    Graham
    Fuegos...
    Thanks for that Jo, cheap is definately appealing. if i could pick up one for under a grand and strip it out, then do some minor suspention tweaks, i think i would be pretty happy.
    What needs to be done to get cars approved for use on the track? Are there any saftey requirements?
    8,394
    Dont forget your yellow and blue GT stripe, just in case anyone forgets who renault is,or for when the Nissan crew wanna have a stab.
    Jo
    Ipswich, Queensland.
    1,885
    For just the street sprint series up here a roadworthy car is all that is necessary. Hillclimbs will require an extinguisher, tape on the lights and a battery marker. After that you get serious. MUST have a full cage and harness for true circuit racing. Most of us will never get that far.
    There are a couple of Fuegos circuit racing up here. Certainly not megabuck cars, but the guys have a heap of fun near the back of the grid.
    By comparison a friend has just finished the build up of a 2L Cosworth motor for an Escort. Basically the best of everything costs up toward $30 000, just for the motor and ancilleries. The car probably owes $60 000. How fast do you want to go???
    '56 Renault 750 (16TS Power)
    '62 Renault Dauphine Gordini
    '08 Renault Megane sedan
    al
    al is offline
    Dec 2004
    2,012
    Quote Originally Posted by alan moore
    I took a mates porsche GT3 for a spin the other night...that would do
    Realistically though, i don't think i could do a fast car justice until i learn how to drive fast. If i'm any good, and i have fun, i would be up for spending some cash on a fast car, but at the moment i just want to have a bash... (and not in my everyday Mi)
    Also, being a young male i have this desire to see how fast my car will go. Obviously the roads aren't the place for this behaviour, so i am looking for somewhere appropriate to practice some "spirited" driving.
    Anyway, i think the answer to the question is as fast as i can cheaply. This isn't going to be an overly serious venture for me, so hopefully i can get something and just have some fun...
    Fellow Frogger! DejaVu's Avatar
    Sep 2004
    Croydon, Melbourne
    693
    that wouldn't happen to be a yellow one would it? coz i see one of them banging around warrandyte, and jumping creek road every so often... i want it!
    but yeah, i hope to put my Mi16 on a track one day... maybe next year when ive got the money. strip it right out, suspension, and minor engine tweaks. im definately going to be paying lots of attention to this thread.
    would you need any additional cooling to make you dont cook something? like a better radiator or oil cooling or something?
    2013 Megane RS 265 Trophy
