205 GTi Modifications
Results 1 to 22 of 22
    Apr 2005
    11
    Default 205 GTi Modifications
    Hi All,
    I just bought a 205 GTi last night Im very happy cos its in good condition at it was cheap. My previous car was a Nissan 200sx which I sold to make way for a first home purchase.
    1st impression from this 88 model GTi are quite impressive, it handles like a go kart and has some impressive accelaration.
    Anyway, Im wanting to modfy this car however im having difficulty in finding suppliers and information in AUS. So here i am
    Rims: The current car has 14" rims - I want to go 15" as in the later models - Will there be any issues with this? Also, what is the fatest tyre you can put on those 15"'s ?
    Brakes: I understand the later version had disks at all corners - Are the rear disks/calipers easy to bolt up - or is their som fabrications involved?
    Suspension: Are their any reputaple local suspension shops that can sort me out with shocks, pushes, sway bars, etc?
    Intake: Can I get a pod filter kit (K&N?) that will bolt up to the air intake? Where from?
    Exhaust: what is the recommended setup? 2" / 2.5" ? Also, are there any bolt on manifolds made/supplied locally?
    And lastly....
    Fuel: Whats the recommended fuel upgrade path? - Fuel pump/injectors/chip? where can i look?
    Thanks very much in advance for any responses.
    Terry
    Fellow Frogger! briz205's Avatar
    Oct 2003
    Auckland New Zealand
    894
    Terry,
    These are the people you need to talk to on the forum
    1. PeterT - all engine work
    2. Ray - koni Shocks
    Cheers Nick
    Auckland NZ -
    2000 Peugeot 406 Coupe, Dark Green.
    2001 Renault Clio Sport RS, Silver.
    Brisbane Aus -
    1989 Peugeot 205 GTi, Light Blue.
    Fellow Frogger! pugpete's Avatar
    Mar 2005
    Canberra, ACT
    231
    Quote Originally Posted by z00sx
    Hi All,
    And lastly....
    Terry
    me too tell me.... i want that stuff...
    205GTi Peugeot 1988 Graphite Grey for sale $2500
    Ipswich, Queensland.
    1,885
    If you use the search on this forum you'll find that there is enough info to keep you reading for a month. But to start you,
    2 1/4" Exhaust Don't worry about extractors.
    Put in replacement K&N in the std airbox
    4 X108 PCD wheels, Just go see Bob Jane etc Pug wheels too heavy 205/50/15 max.
    Koni sports from Ray Bell for best prices.
    '56 Renault 750 (16TS Power)
    '62 Renault Dauphine Gordini
    '08 Renault Megane sedan
    melb
    4,377
    tezza
    Dont touch the zhortz bro. Its a good item as is, maybe a commodore cat though.
    The 15" speedline rims your talking about will fit no worries.
    theres heaps of modification threads in regards to the 205 so do a search, theres plenty of good reading to be had
    Apr 2005
    11
    thanks all for your responses - i will use the search option (im lazy)
    thanks again.
    123
    Icon11
    thanks again.
    WHEELS:- call Ian at EUROSERVE in Brisbane, he has a set of 15" wheels from a series 3 GTI with near new PIRELLI tyres, 0738521399.
    Oct 2002
    Victoria
    65
    Quote Originally Posted by alan moore
    Have you actually weighed the Pug 15" wheels Alan? I would be interested to know the figure if you have.
    Rick Dathan
    Apr 2005
    11
    Quote Originally Posted by maxie
    Thanks mate, but im in Sydney Besides ill be getting semi slicks so id be wasiting the Pirellis.
    T
    9,175
    Hi All,
    And lastly....
    Terry
    I'm in the process of fitting a fuel only aftermarket ECU, should have it going in a week or so.
    Does anyone have a pin out diagram for the factory ECU?
    Graham
    303
    Graham
    Sent you a PDF via email hope it helps.
    Jarrod
    1,885
    The std 15" wheel and tyre is 19Kg, a 14" wheel and tyre 18Kg. Tyre is around 9Kg. Wheels are available around 6-6.5 Kg. Light weight race wheels (not suitable for hitting kerbs or road use) will come down to 4.5 Kg with a price to match generally.
    7,446
    I've got a Haltech F3 and 205 harness if you're interested.
    9,175
    Quote Originally Posted by jarrods
    Jarrod
    Took the plug cover off and found the numbers!! Still the time wasn't altogether wasted as I now have a better understanding of the wiring system.
    I thought the RWD cars had the numbers all along the wire, but maybe I'm mistaken.
    Graham
    Member 406bliss's Avatar
    Feb 2005
    69
    Default 15" wheels
    T
    I have a set of 4 15" 306 wheels that will fit your 205.
    tyres are crap but wheels are same size as 205 15".
    See attached.
    Let me know if you are interseted
    David, 9896 8919, Sydney.
    Fellow Frogger! neil's Avatar
    Apr 2002
    brisbane
    323
    Stop the F%cking about and put an Mi16 motor in, do the koni's and have some fun.
    neil
    205GTI/Mi16
    Tony Sprint Kart
    Oct 2002
    Victoria
    65
    Thanks Alan. As soon as I read your response I went under the house and got out my spare wheel. This weighs 16.2kg with a Continental Sport Contact 185/55/15 tyre with ~5mm tread depth. Assuming your 9kg tyre is accurate (good estimate?) then the wheel (std 205GTI 15") is about 7kg. Maybe I should take my scales next time I pass a tyre retailer.
    Rick
    1000+ Posts pgti6's Avatar
    May 2001
    1,612
    FWIW,
    Mi16 15"x6" rims only weigh 8.6kgs ea.
    Jeff
    Lap times-
    Sandown 1 27.9
    Phillip Island 1 53.8
    Previous Frenchies-
    1988 205Gti
    1998 306 GTi6
    1997 306 N5 sedan
    1996 306 N3 XT hatch
    7,446
    Quote Originally Posted by pgti6
    FWIW,
    Jeff
    Only 8.6Kg ?????
    Oct 2002
    Victoria
    65
    Now for the facts! I bought new tyres today for the 205 (kindly policeman suggested I do and gave it to me in writing last Saturday). While having the tyres fitted, I took one of the rims next door to an automotive paint place and used their digital scales.
    The 15" Pug 205GTI wheels weigh 8.9kg.
    Now that is HEAVY. As I have some concerns about the wheels being a tad narrow for the 205/50/15 Toyo RA-1 tyres I use, it is certainly worth me considering new wheels at some point.
    As for the tyres (which are a competition type tyre that I get 15-20k km out of, depending on how much racing I do), in Aug 2001 they were $180 each (when Yoki A032Rs were $280 each), in Dec 2002 they were $200 each, this time they were $240 each. Anyone else have a price on these? Am I still getting a good deal? At this price I should consider the Dunlop equivalent, as they make a better size for the Pug - 195/50 or 195/55 I think.
    7,446
    The standard tyre was 185/55/15. Most fit 195/50/15. Anything bigger is useless on a 6" rim. The std. wheels are very heavy. Even steel rims are lighter.
    1000+ Posts tekkie's Avatar
    Jun 2002
    1,516
    whether its a good deal is relative to:
    what are you using them for?
    For sprints softest tyre like RA-1 or Ao32R is it. For medium length events Dunlop DOJR or AO32R may offer a better value for money. For Targas Dunlops would be best choice but heard of AO32Rs lasting well. For cruising the sydney carparks doing burnouts those tyres do not present good value.
