Block Drain?
Results 1 to 7 of 7
Thread: Block Drain?
    Jul 2004
    CLARE SA
    2,324
    Default Block Drain?
    Guys, the best way to drain all coollant from block of a 504 is?....................
    thanks ed ge
    Perth Western Australia
    2,678
    Default Block drain.
    Ed,
    To drain all coolant from a 504.
    1. Turn on your heater.
    2. Locate drain plug at rear right hand side of block. Undo. Take care, HOT.
    3. Loosen radiator drain cock.
    To flush system, remove heater hose from water pump. Push your garden hose into the heater hose. Turn on tap to flush system incl. radiator.
    When water runs clear let it run dry, refit heater hose to pump after cleaning pump spout and applying non hardening gasket sealer. NOT silastic etc!
    Refit block drain plug with its washer, I wrap the the thread with PTFE tape.
    Tighten radiator drain.
    Refill system slowly then start engine. Observe the level in the radiator as it will drop when thermostat opens. Top up system with quality coolant. Rain water or distilled water by itself is no good.
    If you haven't done so, consider fitting a recovery system to your radiator.
    Theoretically it prevents air getting into the cooling system and also you shouldn't need to top up the system as often. x2.
    Jul 2004
    CLARE SA
    2,324
    Drain plug similar to sump plug? or?................t'is difficult to see all in this area,................easier from underneath?
    Thanks Beestie/Thanks Wildee/Thankyou Sir............
    ed ge
    2,678
    Default Block drain
    Edg,
    You are going to need to get down and dirty for this one. Beware the hot manifold.
    If I recall the plug has a 17 or 19mm head. Because of its location it will mean lots of spanner shuffling. Very little to no room for a ratchet. Although knowing the magnificent tool kit you have you may even have a set of those "shorty" ratchet ring spanners. They look the goods.
    Jul 2004
    CLARE SA
    2,324
    Not as expansive as to run to those individual ratchet thingies but plenty good for most everything, and I'm already dirty from todays filter change, just couldn't be bothered dragging over the trolley jack that late in the innings. Tomorrow however is another car workin', beer drinking, footy watching, saturday and this is still australia and I'm no nancy boy and ya just gotta get up close and personal with something really greasy c'os mate ................... it's the weekend.
    cheers ed ge
    12,256
    Quote Originally Posted by Wildebeest
    just make sure the cap pressure is correct on the recovery tank as i have seen this fitted to 504's before to only put extra pressure in the system and blow the liner seals within 6 months
    1 x '98 306 GTi6
    Jul 2004
    CLARE SA
    2,324
    Pugrambo,
    there is already a black tube to plastic resevoir set up, but it only has a plastic snapon cap, can't see it providing much pressure, will leave it and see what happens, not much I suspect.
    Cannot/willnot tamper with best efforts of the Irontite God. All praise Irontite.
    ed ge
