Gremlins in the 205
    Member burkey's Avatar
    Mar 2005
    57
    Default Gremlins in the 205
    Gizmo and his fury friends are at it again.....
    Ive got troubles with my indicators, they are working for like three or four blinks then stop. No sound from the glove box when this happens. They start up again if i turn off the indicator and back on again.
    Has anyone else had this problem, and how easy was it to fix and a cost. It is a 205SI 1992.
    I'm just waiting to get pulled over and or rear ended
    Thanks in advance
    Burkey.
    Mar 2005
    57
    anyone???
    Apr 2005
    863
    Quote Originally Posted by burkey
    anyone???
    just a guess, but could be the flasher unit. Maybe the bi metal strip (assuming it isn't electronic) stops working after a few blinks due to heat??? can't imagine a flasher unit being real expensive, probably under $20, and should just be a case of pull out the old one, and plug in the new one..... not sure but I'd guess it is in the fuse/relay box, in the top back of the glove box...
    Tony.
    306 S16 1995 black
    Morris 1100 1965 green
    Member plasmapug's Avatar
    58
    This probably isn't the solution to your problem, but good to note anyway.....
    My indicators used to bugger up every now and again and you'd hear a sound from the relay. Sometimes they wouldn't come on at all. The culprit? My hazard light switch. When the switch was on, the hazard lights would work fine, but when off, the indicators played up. The hazard switch disconnects the indicator circuit when on so when it failed, it left the indicator circuit open.
    Pete
    '88 205GTi
