Flashlube For Pinging
Results 1 to 12 of 12
    mlb
    mlb is offline
    Voted Most Popular mlb's Avatar
    Jan 2005
    Devonport, Tasmania
    1,102
    Default Flashlube For Pinging
    Just a quick question.
    Does Flashlube, or any other similar fuel additive, have any effect on the octane level of fuel? I've noticed lately that my car has started pinging a little under load. Timing and points are fine, so the only other thing I can think of is a dodgy batch of fuel.
    So would putting a bit of flashlube in the tank help alleviate this in the short term until I can get some better fuel?
    Just a thought
    Matt
    EDIT: I should say I am already running PULP, just in case anyone was going to suggest it.
    Fight for your opinions, but do not believe that they contain the whole truth, or the only truth.
    12,256
    i'd say a dud batch of fuel
    i get it sometimes in the 604 but it's not standard either
    i find that when the water runs out for the water injection and it has something other than BP PULP in it and it is a hot day it will ping
    the car is set at the standard 12deg static timing
    if i run 98 octane i have no trouble at all
    the water/metho helps a lot though i have found and also improves performance and economy
    i only ever use the water injection when i am running the car out of town so i don't have to worry about running it on relatively short trips around town
    very simple setup and it only costs around $2 to set up so it's not quite in the 50c club but damn close
    1 x '98 306 GTi6
    Mar 2003
    Location Location
    1,574
    Pugrambo - do you have a link to your guide for setting up water injection?
    Also, do you find it useful to counteract valve recession or do you need to use upper cyl lube as well?
    12,256
    Quote Originally Posted by graham66
    i'll try and find the link but the crux of it all is
    you need a range of hypodermic needles from the chemist, some air line hose from the pet shop, a toe from your better 1/2's stockings she put a stairway to heaven in , and a container to hold water
    you then put the container where you can find room at a level below the carby
    place some stocking over one end of the hose to act as a filter and place in the container
    ensure the container has a hole in the lid to allow air to enter as water level goes down
    place the needle in the other end of the hose
    make sure the hose is long enough to reach the carby
    find the vacuum line for the dissy going into the carby
    feed the needle into the rubber line so it protudes out of the end of the rubber line
    place the vacuum line back onto the carby and if need be place a little silastic around where the needle enters the line to ensure an air tight join
    place some water or water/metho in the bottle
    start the car and at idle you should not have any water in the lines, then crack the throttle to around 1500-2000rpm and watch to make sure the water starts to flow
    with the lines empty the water flow will be fairly fast but then cut back to a trickle
    you will be able to hear slightly the water entering the throat in the carby at revs
    watch out the rear of the car when doing this as you will start to get some black gunk coming out as it will be cleaning the carbon out at the same time so don't do any of this in the back yard with the car backed up near the clothes line otherwise youe other 1/2 will be a little upset
    go for a drive and see how the car goes and if you want you can advance the timing little by little untill it pings and then back it off a tad
    make sure that where you set the dissy that the car will start when cold
    you should be able to safely run up to around 6-8deg more advance over standard on a standard engine
    the performance will astound you and the economy will follow
    the next thing is to see how much water you are using
    you should be using around 5-15% water
    so around 2L of water should last you a tankfull of fuel in a normal car
    before the old engine blew a head gasket i had been running water injection and the car went from 13mpg to 20 mpg and more power from a 400k old engine
    when the engine was pulled down it was as clean as a whistle inside without a spec of carbon to be found
    the water slows the flame front down and cools the charge so the burn on ignition stroke is burning most of the way pushing the piston instead of one big bang
    as for VSR it won't do a thing
    i don't need to worry about VSR as the PRV motor has hard seats
    1 x '98 306 GTi6
    ade
    ade is offline
    Jul 2003
    154
    Default Sparkplugs......
    Pugrambo, I know this will blow the $2 budget but did you use warmer plugs for the water injection?
    12,256
    Quote Originally Posted by ade
    i put standard plug in for the car
    the engine now has 4k on it and it has run in nicely and pulls very hard once you hit around 3k rpm
    i gave it a good run yesterday and had upchanges around 4500-5500 and it sounded good and pulled harder than a teenage boy
    so normal plugs and timing standard as the engine isn't standard
    1 x '98 306 GTi6
    ade
    ade is offline
    Jul 2003
    154
    Default Makes sense when you think about it.
    As you mentioned, you advanced the timing so I imagine any cooling effect may have been countered ('taken advantage of' may be a more appropriate term) thus no need for the change in plugs.
    12,256
    hotter plugs are really only any good if you are either burning oil or you do a lot of very short trips
    with the timing advanced the car will run a bit warmer anyway but as winter is coming on it should be fine
    i don't really worry about changing plugs for seasons or for the injection
    also i am not far away now from finishing off the fuel injection for the car
    i'm going to hunt around for some EFI injectors and probably go megasquirt on the car instead of the mechanical system
    1 x '98 306 GTi6
    mlb
    mlb is offline
    Jan 2005
    Devonport, Tasmania
    1,102
    So 'rambo, this sound far to easy to be true. Surely there must be some draw backs or associated problems.
    And exactly how good are the improvments. If they were that significant, and being a simple fix, I would have thought it would be more common.
    Not doubting, just asking.
    Matt
    12,256
    Quote Originally Posted by mlb
    Matt
    drawbacks are if you run out of water with the timing advanced the car will ping like buggery
    if you do a lot of short trips with the water injection going you will end up with water in the oil in the case of older engines
    some people have always been a bit sceptical of water injection and hence it isn't as common as it used to be
    a lot of the turbo guys use it to have cool charges in the cars but they run a pumped system
    i prefer to run 50/50 water/ethanol (metho)
    benefits are more usable power = better economy
    better burn for ignition stroke = more power = better economy
    1 x '98 306 GTi6
    mlb
    mlb is offline
    Jan 2005
    Devonport, Tasmania
    1,102
    OK, might have to put it on my to do list. I suppose setting the timing is a bit of a hit and miss affair. Set for around 16 degrees in my case, test it, if it pings back it off, if not advance a bit more. Or is there a more technical way to do it?
    12,256
    that's about it
    it all depends on your engine and how much advance it can handle
    the only thing you need to watch is that you can start it cold with the advance set at more than standard so the best trick is to do it when you aren't working the next day so you have some time to fiddle if need be
    metho no name brand is a bit over $1/L but you can run straight water if you want
    1 x '98 306 GTi6
