405 SRDT Engine
Thread: 405 SRDT Engine
    Feb 2002
    Tamworth NSW
    496
    Icon7 405 SRDT Engine
    I recently heard about a problem which may occur with some 405 SRDT engines.
    Apparently the vacuum pump is driven directly from the camshaft. In the event of the vacuum pump seizing, the load applied to the camshaft is sufficient to break the camshaft, and cause substantial internal engine damage.
    The cost of an engine repair usually exceeds the market value of the vehicle, and hence the car may end up at the wreckers etc. For those considering that another engine from a wreckers yard could be a solution, it is if you can find one. Apparently the SRDT engine is a popular fitment to Bobcats, and that fraternity usually lay claims to any serviceable engines fitted to SRDT's found in the wrecking yards.
    A new vacuum pump I am told is about $400.00. Has any body experienced or heard of this incident?
    Kim.
    Banned renaulturbo's Avatar
    melbourne,victoria
    523
    Quote Originally Posted by KIMDEB
    Kim.
    Talking about expensive, i bent 4 valves recently on my SRDT and so far ive spent $140 on VRS kit and head gasket, $350 for reco of head+cost of new valves ($20 each), $500 for recoed injectors and ive been asked for $970 for reco of turbocharger (new compressor wheel and oversized bearings). Couldnt imagine how much a cam would cost...
    Yesterday i went to Fowles to see a SRDT statutory write off (engine bay was perfect!) but since its rent paying week, i couldnt out bid the guy from BM spares There was actually another one but had received a big hit in the front
    I couldnt believe there being two on the same day...i hope there's more to come! Thats all u need...a whole car for spares
    Feb 2002
    Tamworth NSW
    496
    Icon7
    That is an expensive repair!!
    How did you bend the valves? Broken / slipped cam belt?
    How many km's has the engine done?
    Kim.
    12,256
    if you broke a belt i'm suprised you got away with only 4 valves and the cam shaft is still ok
    i'd be replacing the others just in case as it's quite unusual that you would only bend 4
    $20/valve is cheap so i take it you didn't get them through a dealer
    1 x '98 306 GTi6
