Odd-Fire PRV Cams
Results 1 to 25 of 26
    Feb 2005
    Colorado Springs, USA
    17
    Default Odd-Fire PRV Cams
    Anyone have a source for performance cams for the odd-fire PRV?
    Feb 2005
    17
    C'mon....somebody must know someone that has a better than stock set of cams...can anyone recommend a desired lift and duration for a performance cam that will work without having to change other valve train components?
    9,175
    Quote Originally Posted by Volvo Rick
    Yes, Crow cams in Melbourne have a cam which works, this was developed in conjunction with some PCCV members, don't know any details
    www.crowcams.com.au
    Graham
    Feb 2005
    17
    Graham, Thanks for the response!
    Feb 2005
    17
    I chatted with Ray of Crow cams. He said he hasn't had any b27 or b28 billets to make cams for awhile. Any other reputable source? Thanks, Rick
    9,175
    No I think they are the only ones that have sorted these cams out. Others may claim to have but I would think you would be dissapointed with them.
    Graham
    Fellow Frogger! aquinian's Avatar
    WA
    604
    Camshaft Engineering in Osborne Park, WA, do 2850cc (odd-fire) cam regrinds for $79 per cam. I had them do mine, and they are perfect. Not a "performance" grind but higher lift than the original 2700cc cams.
    John Lane.
    1000+ Posts Warwick's Avatar
    Nov 2002
    2,664
    See if you can contact member "oddfirev6" or whatever his moniker is. Rob knows a bit about this sort of thing.
    Why wouldn't you take the cams to Wades and get the grind of your choice?
    WA
    604
    Quote Originally Posted by Warwick
    Yes, I know Rob and he gave me a lot of help with my own project. Why wouldn't you go to Wades? Two reasons - cost, and the inherent complexity of the task. The first of these reasons speaks for itself. The second is demonstrated in the lengthy and challenging exercises gone through over the years by Rob and others in their endeavours to get a good "performance" profile worked out with Crow Cams. Why reinvent the wheel?
    John Lane.
    9,175
    Quote Originally Posted by aquinian
    John Lane.
    I've never found Wades to be expensive but I fully agree with the second reason.
    Graham
    WA
    604
    Graham
    Graham,
    I don't know Wades from a jar of vegemite, so no comment was intended concerning them in particular. Only that a custom grind is going to be a lot more costly than $79 per cam. (And if it isn't, let me know and I'll give 'em a job today!)
    John.
    Fellow Frogger! OddFireV6's Avatar
    152
    Dear fellow Camshaft experts
    I hope like all those who own really big degree wheels and not one but two dial indicators you are in a position to back claims you may make in relation to the quality or otherwise of various camshafts. Note the measurements of standard ex factory Volvo B28 type 3 camshafts in the attachment.
    Any claim of PRV cam perfection cannot be established without hard numbers as above, by the way note the lack of perfection in the numbers in the attachment. The Crow HiPo cams by the way are 9.8mm lift, 300-310 deg duration and about 75 deg overlap
    Now the Wade organisation is a quality camshaft builder, their standard regrinds are slightly less lift than a standard 604 grind and so not much good for high performance engines. Now when pushed to do a high performance oddfire cam they took 3 attempts to get the overlap correct between each bank and the final result was in fact particularly good. So much bother was this incident though that Wades, in my experience, are not prepared to do any oddfire cam regrind other than standard 604/Volvo 264.
    After years of bitter experience we have yet to discover anyone in Australia who can reproduce high performance PRV V6 cams other than Crow, the usual cost is $500 or so a pair using new billets. If such and organisation does exist I would like to know about this fact rather than go through another bout of disappointment and wasted hours in yet another set of cams that are too far out equivalence in the timing between left and right sides of the engine to be considered acceptable.
    Attached Files Attached Files
    OddfireV6
    504 V6 24V, 203
    WA
    604
    Quote Originally Posted by OddFireV6
    Ouch!
    Current: 406 Coupe, 504 Sedan
    Previous: 306XSi, 205GTi, 206Gti, 505 V6, 505 Wagon, 504 Sedan, 504 Wagon, 306Gti6, 306XT, 205Si, Citroen XM, Citroen Xantia
    Feb 2005
    17
    So what is the current best choice cams for performance for an odd-fire PRV? 1980 Volvo B28 cams? Thanks, Rick
    Member eatpeople04's Avatar
    Apr 2005
    Eltham, Victoria
    116
    And while we are hovering about the subject, has anyone had any experience with 2.2 Douvrin OHC Cam profiles? Does anyone make a higher lift one of them than the original Unleaded GTi?
    eatpeople04
    Now showing in:
    "Betty" 1997 Black 306 GTi6
    "Shaggy" 2001 Green Subaru Outback
    The Mrs. Has
    "Wags" 2006 Ash Grey 307 XSE Hdi Touring
    And for floating...
    "Korka" 1978 Red/Blue Ramsay Lynx with 327ci Chevy
    Previously:
    "Cliff the 505th" 1985 White 505 GTi
    "Clive the 505" 1983 Poo Gold? 505 STi RIP
    Dec 2002
    2,528
    Quote Originally Posted by eatpeople04
    Yes, they came out of the Douvrin factory. Both the earlier leaded 2.2 litre and the 2 litre renditions of the motor had higher lift and longer duration than the unleaded versions. They make a noticeable difference when installed in conjunction with increasing compression ratios.
    Scotty
    Melbourne - Dandenong Ranges
    2014 Peugeot RCZ - 'Remy'
    Feb 2005
    17
    Does anyone know if the Talbot Tagora 2.6 cams are worth trying to locate? Thanks, Rick
    Dec 2002
    2,528
    I didn't think that they were any different to the Peugeot/Volvo 2664cc cams.
    You're better off with the 2850 ones.
    Scotty
    12,256
    i have the highest lift 2850 cams in the 604 with 91mm pistons
    the engine pulls harder than a teenage boy but you have to watch for pinging though
    i run 98 octane and it can still ping but with water injection it stops pinging
    next will be a megasquirt injection setup on it to really make the best of it as the carb is strangling it a bit
    i have been told that the exhaust is louder now and has a better note than before the rebuild and i'll admit it does sound great
    i was thinking of putting a bigger free'er flowing system on it but i think it may attract the boys in blue
    1 x '98 306 GTi6
    1000+ Posts bowie's Avatar
    Aug 2002
    Sydney, Concord City, Sir.
    3,372
    attrack boys in blue.. They'll hear it.. and look behind and to the side of you wanting to see where that mad ol noise is comming from..
    Feb 2005
    17
    Sean, What cams are you running? Where did you get them from? Thanks, Rick
    12,256
    b28 cams from a 264 volvo aus spec
    1 x '98 306 GTi6
    Feb 2005
    17
    Sean, Do you happen to know the specs of your stock Volvo cams? Are there any other folks that might have a lead on the Crow Cam specs? I've chatted with Ray at Crow and I keep getting that they did seven different grinds for the PRV from mild to wild but haven't gotten Ray to share the specs. I'm just trying to find a street performance grind.
    Fellow Frogger! Covert's Avatar
    Covert
    449
    Now I am no expert but some of the Alpine dudes here in melbourne have also been mucking around with the PRV cams as well, they often talk about places in france, but I have found it is also like understanding the black arts.... with these engines and cams. Having seen OddFireV6 car at various french car days I'd say he knows his stuff. Maybe someone else is Colin from Alpine Affaire who has dealt with the alpine side of things. http://www.alpineaffaire.com.au/
    All I know is that the cold hard specs/figures seem to be one hard thing to get you hands on, and the other is the place to make the cams. I know i am waiting on the side lines always looking at this subject so that one day I can build up a engine for my A310.
    Here are some links below out of interest ...
    http://www.simon-auto.de/alpine/engl...310_tuning.htm
    Engine-tuning wir liefern diverse Artikel zum Thema Motortuning:
    - Order-Nr. 241257, sport camshaft 296°, left
    - Order-Nr. 241258, sport camshaft 296°, right
    http://www.ferrydev.com/
    The famous french engine tuners..... look at link below for engine stuff
    there are cams there somewhere, just can't find it in all that french :-)
    http://www.ferrydev.com/ens_mobile.htm
    And at the Renault Alpine forum in the uk, chris refers to ferry dev cams etc
    http://www.renaultalpine.co.uk/
    www.renaultalpine.co.uk Forum Index -> General Discussion -> performance Camshafts
    http://www.renaultalpine.co.uk/PHPBB...587&highlight=
    Chris Whyman GTA
    http://www.renaultalpine.co.uk/australia_visitors.htm
    I don't know if this all adds to the conversation, but it maybe of some help
    regards
    Feb 2005
    17
    Thanks Covert....great leads!!
