Oxidised paint and bird **** stains....how to get rid?
Results 1 to 14 of 14
    Fellow Frogger! Pug-a-lug's Avatar
    Jun 2004
    172
    Default Oxidised paint and bird **** stains....how to get rid?
    Okay, in general the paint finish on my '91 205 GTi is pretty good.
    Since January '03 I've been using :
    Meguire's Deep Crystal Paint Cleaner, followed by :
    The Deep Crystal Polish, and finishing with :
    The Deep Crystal Wax.
    Besides a few nicks and bird **** stains, generally the finish has been holding up well....until recently.
    Last year I noticed some discolouration in the middle of the bonnet. Using the usual three-step method didn't remove it. Consultation with mates has led me to believe that it is most likely oxidisation.
    I was going to try to use a cutter the next time I washed/waxed the car, and was wondering what people's opinions would be.
    I've trawled the forums, and see that people either recommend the 3M micro-polishing something or other... or Meguire's Scratch X. People are also talking about clays (which I've never heard of), but from their description they seem to be more suited to 'baked on grime', as opposed to flaws in the paint.
    Will a cutter get rid of this oxidisation?
    Or will I have to *gulp* look at re-spraying?
    Simon's Avatar
    6,161
    Is it metallic paint? If so it is likely the clear coat deteriorating (oxidising). Best solution is a respray, or a stronger cut and polish in the interim period before the clear coat totally deteriorates and turns into dandruff.........
    Jun 2004
    172
    Quote Originally Posted by Simon
    Yeah, its metallic paint. Gun-metal grey.
    Jul 2004
    nth balwyn, victoria
    1,428
    good cut and polish and respray the clear coat if ya wanna go for it.
    its hard to tell how bad it is by the description so maybe get a spraypainter to look at it.
    -BAZZ
    8,176
    Icon3
    Pug-a-lug, not good news I'm afraid...
    I'd say from your description, your bonnet has already had a clear coat applied to a poorly prepared surface. The heat from engine and sun has possibly caused the clear coat to deteriorate and break down, hence the problem is more prevalent where the heat is concentrated, metalic paints are more prone to this than solid colours. If this is the case then no amount of polishing is going to restore it.
    Sounds like the bonnet will need a re-spray
    08 C5 X7 HDi very Noir
    Gordon, NSW
    4,527
    You need to use a polish with a slight abrasive. Scratch X should do it:
    http://www.bettercarcare.com/articles.php?articleId=53
    I used Meguiar's DACD with a random orbital to get rid of it. Clay won't do much in this instance, but before you start at it with the scratch X it would be a good idea to remove any surface contaminants.
    http://www.bettercarcare.com/articles.php?articleId=14
    Got any pics of the problem?
    - Lincoln
    Jun 2004
    172
    Quote Originally Posted by GreenBlood
    Yep, friends of mine who have seen it first hand have given the exact diagnosis. The discolouration is a small patch smack-bang in the middle of the bonnet, right above the engine.
    I'll try and take pictures of it tomorrow.
    EDIT : Here are the pics.
    It probably shows up best in the last photo. Note how the tops of some of the pickets in the fence are all blurred and smudged.
    Jun 2004
    172
    Posted the pics today.
    Apr 2005
    863
    Quote Originally Posted by Pug-a-lug
    Looks like what happened to my Black S16 on the bonnet and roof. Clear coat basically delaminates, and causes a milky look. Just got mine resprayed, when I had to take it in for repairs due to someone t-boning me.
    as far as fixing minor oxidation and scratches I always use meguiars fine cut cleaner, with a random orbit sander (variable speed one) and meguiars polishing pads. follow up with no 7 polish (sometimes I will use swirl remover then the polish), and finally with medalion wax (now called gold class wax). funilly I just went to their site and they don't have fine, medium and heavy cut cleaner listed anymore
    Tony.
    Jun 2004
    172
    Well I gave it a go with Scratch X on the weekend, and it didn't really do anything.
    And personally, I found little difference in abrasiveness between Scratch X and their Paint Cleaner (which I already use).
    Looks like it will need a respray, although I'm tempted to use a rougher compound as a last resort.
    Apr 2005
    863
    Quick question... have you ever put rainx additive into your washer water? I did once, and I have my suspicions that it is what caused my clear coat delamination..... seemed to correspond with where the water ran down the bonnet from the spray jets, and where the overspray went on the roof.
    Tony.
    306 S16 1995 black
    Morris 1100 1965 green
    16,370
    No amount of cutting is going to fix that. All you'll end up doing is cutting through the clear coat. As soon as you hit the base colour underneath it'll look really bad. Do you want a photo of my CX to prove this (it's clearcoat is lifting & gone done one side of the car).
    Fellow Frogger! frogs4ever's Avatar
    Jan 2003
    Tasmania
    392
    Correct.
    An abrasive polish or cleaner will simply help strip off what's left of your deteriorating clear coat, making matters worse than they already are.
    What's more, the prices charged for some of those name brand cleaning and polishing systems lead me to believe that it wouldn't take terribly long for the cost of a bonnet respray to be recouped when compared with escalating expenditure on car care products.
    2004 Clio Expression Verve 4sp auto -
    1984 Fuego GTX 5 speed (now a write off) -
    1976 504 GL auto (sold)
    French cars, Australian wine.
    Jun 2004
    172
    Quote Originally Posted by frogs4ever
    Hah! Good point!
    Wintermute - I've only ever put Windex in my wiper fluid. The 'hazing' has no relation to the water-jets, I'm pretty sure that it is just an oxidation issue.
