Rejuvenating pollen filters
Results 1 to 14 of 14
    6,248
    Default Rejuvenating pollen filters
    Hi there,
    Is there any way of rejuvenating/servicing pollen filters? I just can't see the need to replace them as frequently as suggested in service schedules - a quick blow out seems to be the go, but what are the arguments for replacement? I've heard of disinfecting them...?
    Stuey
    2003 PEUGEOT 206 GTi
    9,223
    This might sound strange, but I've never heard of pollen filters... what are they?
    6,248
    Ray, a lot of the more modern cars have an element, very similar to an engine air filter element, in the cabin air intake system. They filter out all dust and most if not all pollens, as well as the obvious larger particles. Many also are impregnated with activated charcoal to remove other impurities, and some smells.
    This question relates to my wifes '02 Astra (charcoal impregnated version), but the same applies to all cabin filter elements, so I thought it was OK to ask the ever-reliable Frogger community.
    We've just done some driving around the State's south west, including a bit of gravel stuff, and the air intake became slightly smelly when using the aircon. I removed the filter (glovebox out job) which was full of dust, hair, seeds etc. etc. I've now blown it out, and we'll see how it goes. You can run it without the filter installed, but they are a bonus in my book.
    (Incidentally, the Astra's cabin integrity continues to impress. This (base) model has supple springs and a very stiff monocoque and is great for rough roads, sealed or unsealed. Weirdly, for high speed country driving it's great - it just soaks up low frequency bumps at about 130km/h just beautifully, but for throwing around corners in the city, the handling is quite poor and seemingly underdamped...).
    Cheers (more than you wanted to know, there!)
    Stuey
    9,223
    Underdamped?
    I can arrange some Konis that will fix that...
    Thanks for the detailed explanation.
    12,256
    Stuey
    I just blow mine out and put them back in
    A lot of earthmoving gear have them as well and as we were never allowed to smoke in them we used to spray air freshener on them about an hour before the end of the shift and that would clear any smoke smells from in the cab
    1 x '98 306 GTi6
    6,248
    Thanks Rambo - I've had a bit of a drive today, and the smell is almost gone after a blow-out.
    Underdamped?
    Yes, Ray - very disappointing in what I consider a really good car. The thing is screwed together like a tank, conservatively but well engineered (what I like), but around corners it wallows like the rebound damping isn't controlled. I wouldn't go to the expense of Koni's for it as it's my wife's - who wouldn't notice the difference. Many on here may laugh, but her previous car, a Hyundai Lantra ('97), handled FAR better. Ride was relatively poor, though.
    Stuey
    Fellow Frogger! ipb205's Avatar
    Wright ACT
    560
    Anyone know how to get to the pollen filter in a 206gti?
    ipb
    1000+ Posts Haakon's Avatar
    May 2002
    canberra...
    8,747
    I got to mine with the vacuam cleaner which got all the dust etc out very well. But the discolouration and the smell is still there. Was going to soak it in Febreeze (odour killer stuff for fabrics) before forking out $50 odd for a new one.....
    I reckon they are a godsend for keeping dust out, as I do a lot of country driving on dirt roads.
    5,312
    Quote Originally Posted by Stuey
    Stuey
    Is that a Vauxhall Astra?
    Cheers, Mike.
    Perth Western Australia
    2,678
    Default Rejuvenating pollen filters.
    Hi there,
    Stuey
    Stuey, In the '80's Volvo never had pollen filters,I think SAAB may have been the first.
    When the owners complained about the air con smelling mouldy, the onset of "Legionnaires Disease" ? we would close off all the inside vents etc and liberally spray Glen 20* into the ouside air intake with the fan on full speed.
    It did the trick. I would have liked to tell the owners to give up smoking, the main cause of the smell when the air con was on Recirc.
    *Any hospital type deodoriser would do.
    6,248
    Quote Originally Posted by catshamlet
    Cheers, Mike.
    Yes, Mike, only over here they are badged as Holden Astra - all part of GM. All made in the same factory - they aren't built here. The compliance plate has 'Adem Opel AG' on it.
    Wildebeest, that's a great idea. I wish I'd thought of that while I had it out and I could have sprayed it directly - we have some Glen 20 here somewhere. I'd actually read somewhere that there's a spray used just for that purpose, and wondered what it was - probably Glen 20!!!
    Stuey
    Wright ACT
    560
    Wurth make a product for disinfecting smelly A/C systems - probably just Glen 20 in a German can at 8 x the price though.
    Haakon - While you're there - can you tell me how to replace the 406 pollen filter as my old man has a 97 model.
    Back to my first question - where is the p filter located in the 206 GTi?
    ipb
    1000+ Posts kermit's Avatar
    Jun 2002
    Inner city, Brisbane
    2,335
    Quote Originally Posted by ipb205
    ipb
    Under the bonnet behind the right-handside strut (from drivers perpestive), beneath the windscreen. The vents on the bonnet feed air to it.
    Cheers Simon
    >8-]
    Rendezvous Adelaide 2005
    My Flickr Photos
    206gti.net
    peugeot-206gti
    peugeot-307
    peugeot-407
    peugeotclub.asn.au
    May 2002
    canberra...
    8,747
    park the wipers in the up position, open bonnet and its under the plastic panel on the left of the cowl where the wipers usually rest. Easy to unclip the panel and pull out the panel filter.
