HELP! Damn s16
Results 1 to 13 of 13
Thread: HELP! Damn s16
    19
    Default HELP! Damn s16
    Hey guys
    The S16 has had rough running problems for quite some time now. When idling, there seems to be a miss or a slight drop that happens every 5-10 seconds or so. I have a supersprint muffler and it is very audible from the exhaust note. When under harder acceleration the car doesn't PULL smoothly like it did when i first purchased it. It seems to hesitate a little, (its very hard to describe). I replaced the oxygen sensor and spark plugs the other day and for a day it accellerated very well, however the uneven running at idle was still present. So I have just finished replacing all the coil packs. However the problem is still occuring!
    Any thoughs would be greatly appreciated! Its driving me nuts and im no longer liking my s16.
    Tim
    al
    al is offline
    1000+ Posts al's Avatar
    Dec 2004
    2,012
    Do you find that the problem is isolated to the lower rev range?
    I had this exact prob in my Mi16 recently. I replaced the leads, dizzy cap and rotor and finally solved it with new plugs. As you have done the plugs perhaps it could be related to the leads or dizzy?
    303
    Quote Originally Posted by al_
    I dont think this will be the problem. The S16 has coil packs under the rocker cover which are fired by the engine management. It doesn't have a distributor or leads. Have you had a dealer plug it into their diagnostic computer. This may show if any of the other sensors are faulty although their can't be too many left you haven't replaced. Make sure the wiring and plugs on the sensors are clean and making good connection.
    Jarrod
    al
    al is offline
    Dec 2004
    2,012
    Quote Originally Posted by jarrods
    Jarrod
    lol, probably wouldn't be that then...
    Fellow Frogger! 20FIVE's Avatar
    Jun 2004
    Houston Texas
    150
    Default rough idle S16
    Depending on the age and mileage of the S16 a couple of points to think about would include:
    ~it may be time to have the injectors cleaned
    ~a slightest air leak on one of the many air hoses would lead to rough idle
    ~if one of the actuators which opens the variable length runners is slightly open then there may be air being sucker into both sets of runners during idle and possibly not opening both sets of runners during full throttle hence low performance.
    just a few thoughts.
    Good luck
    2000+ Brad's Avatar
    2,404
    My money would be on the O2 sensor, crank speed/angle sensor or the intake monafold diaphrams. The sensors could cause the hesitation but you've replaced the O2 and the crank sensor will cause bigger problems then hesitation. The poor low end performance is almost certainly the intake diaphrams. Do a search on it, we've covered it numerous times in the past 5 years.
    May 2002
    642
    Not realted to your problem, but was your S16 at Charles Street Auto a few weeks ago, big wheels, supersprint muffler, silver colour, looks awesome
    05' Megane 225 Cup
    19
    Default Thanks guys
    Ill check all of the above. Brad the intake diaphrams were replaced about a year ago. The problem is that sometimes it will accelerate and pull beautifully, but normally it will just rev, without having that smooth pull.
    And pugsy yeah that was mine. Apart for the front bar im pretty happy with the looks!
    2000+ Brad's Avatar
    2,404
    How about the other parts of that system, vacume booster and solenoid?
    1000+ Posts CHRI'S16's Avatar
    Jun 2002
    3,298
    Could be a small intermitten leak in the MAP tubing/hose. This is a small black hose that runs from the front of the plastic intake manifold, (between the runners) and the snakes its way back, through a small plastic filter into the ECU which is mounted on the back case of the battery. Find it by removing the ECU cover andf on the top corner of the box you will see a small (8mm) black hose, follow this very carefully and make sure it's not damaged. If this has a leak or a small cut/kink it wont let the ECU read properly, and it wont fuel the engine properly. Check this too, as its an easy fix. - Chris
    ... ptui!
    Jan 2005
    Melbourne NSW
    813
    i had a problem with the engine faultering at lower revs in dads 306xt, and narrowed it down to the idle motor (it didnt take long to find the problem, i just asked one of the others at work!)
    Apr 2005
    863
    Hi Tim,
    Did you get it sorted? don't know if you saw my post re cracked vacuum tube. S16 cracked vacuum pipe. Oh what a difference! fixing it made a big difference to my acceleration, car was very hesitant now quite smooth. It is also possible that it was one of my crank case breather hoses (cause I found and fixed that at the same time) but I think it was more than likely the vacuum tube.
    it runs from the throttle body to a purge valve, then to the charcoal canistor (thanks to Stuey for the hint on what it was ).
    Tony.
    306 S16 1995 black
    Morris 1100 1965 green
    Member senthil16V's Avatar
    malaysia
    102
    Quote Originally Posted by CHRI'S16
    Yes, chris is right...i had a similiar problem quite sometime back...its was a small leak at the 8mm hose that goes into ECU...i replaced it and the car idled and picked up smoothly after that...
    just a pointer, since your car could be more than 10 years old...i would recommend to change all the vacuum hoses so that this problem does not persist...once you have changed all of them, then you will love your S16 again !
    With Rgds,
    Senthil16V
