GTi6 Engine "STOP" light
Results 1 to 9 of 9
    Fellow Frogger! WRCPUG's Avatar
    May 2002
    Glen Iris, Melbourne
    1,035
    Default GTi6 Engine "STOP" light
    Occasionally when i drive and the car is warm (usually a little above 90 degrees water temp) the STOP light comes on in my dash cluster.
    This has happened a few times in the past week the longest it stays on is 20-30 seconds and even when i clutch in it will stay on.
    Is this an electrical fault or does it something to do with the cars knock sensor? Does anyone know the parameters that will set this warning light to come on.
    NOTE-
    My motor is going to have the headgasket replaced ASAP as i think it has a hairline fracture as oil has seeped into my cooling system and my radiatior, hoses and end tank are all filled with a brownish paste/disgusting gue. Its lining my radiator hose (i checked it its a few mm thick lining the hose).
    My car is running a little hotter than usual (but never much more than 90) and im pretty sure this warning STOP light has something to do with this headgasket problem.
    Any help would be greatly appreciated (regarding the warning light) The headgasket is getting taken of ASAP.
    Alex
    PEUGEOT 306 GTi6 (1997-1999 HYBRID)
    105.4kw (141HP) ATW
    2:09 Phillip Island (Toyo Street Tyres)
    2001 YAMAHA YZF-R6
    119HP
    1993 MITSUBISHI 3000GT Twin Turbo
    300BHP
    STOCK-14.006 @97.4mph HEATHCOTE
    STOCK-1:15 CALDER Long Circuit (Stock Street Tyres + Stock Pads :banghead )
    (For Sale)
    Banned orestes's Avatar
    Sunshine Coast
    4,520
    you sure that it's not over heating ??
    12,256
    mine has hit the 100 mark once when a fan failed but the other one was still going and it was a stinker of a day and i didn't get any lights up on the dash
    it could be warm but then it would also be a bad connection somewhere as well
    1 x '98 306 GTi6
    Tadpole birdee_numnum's Avatar
    Sep 2004
    16
    could it be that the oil that is seeping into your cooling system is much hotter than 90c and clagging onto a coolant temp sensor or similar and sensing much hotter (thus tripping computer)... dunno about you but i wouldn't keep driving it with the head gasket like that for fear of bigger problems developing (and $$$) that may result from doing so...
    May 2002
    1,035
    I think the crack in the gasket was very small....only a small amount of water was seeping into the cylinder...i checked the plugs last week...they do show small signs of a leaking gasket but nothing huge.
    The oil in the system is not that much hotter but it is clogging up the system and looks disgusting.
    I really dont want to drive it but have no choice until i can get our mechanic to fix the head gasket.
    105.4kw (141HP) ATW
    2001 YAMAHA YZF-R6
    119HP
    300BHP
    (For Sale)
    Fellow Frogger! slick's Avatar
    Nov 2003
    Sydney Australia
    506
    Quote Originally Posted by WRCPUG
    This has happened once for me in my 306 S16 just before I fixed up the water pump. I drove the car for a few 10 mins to the shops. I stopped for 10 minutes and then when I started the car again on the way home the STOP light flashed about 3 times for 5 secs each time. It hadnt done it since and I just assummed it's a small electrical problem. The temperatures never really exceed 90 degrees and the car's running really well after a service in Feb
    1994 306 S16 sold but not forgotten
    2004 Clio 182 current
    May 2002
    1,035
    haha BTW nice username Birdy_Numnum. I love that movie
    105.4kw (141HP) ATW
    2001 YAMAHA YZF-R6
    119HP
    300BHP
    (For Sale)
    1000+ Posts U Turn's Avatar
    1,761
    I didn't know the gti6 had a knock sensor!? I've never heard mine ping so wouldn't know. Can anyone confirm?
    Take the long way home....
    - 306 gti6
    Sep 2003
    North Parramatta
    3,996
    Hmm, sounds like using the car is a dodgy proposition to me. It can quickly turn from "just a quick head gasket change" into something a lot more expensive.
    I haven't read anywhere that you have checked the coolant level at all. Could this not be what your stop light is complaining about?
    Simon
    2018 308 GTi 2011 DS3 DSport
    www.peugeotclub.asn.au
