505 ZDJK/L Alternator
Results 1 to 8 of 8
    Feb 2002
    Tamworth NSW
    496
    Icon7 505 ZDJK/L Alternator
    Has anyone found a suitable alternative to the Motorola alternator fitted to these 505 engines?
    I have just repaired such a Motorola unit by having spare parts from a spare alternator. It did also require a new regulator, as the original literally fried itself.
    Experience and evidence from other 505 owners suggests that once the slip-rings become too worn, rectifier burns out etc, the Motorola unit is simply un-economical to repair.
    I believe that there is a Bosch unit which can be fitted. Anybody replaced their Motorola with something else?
    Kim.
    Member alan_505's Avatar
    Melbourne,Victoria,Australia
    42
    I have replaced my motorola regulator with a higher voltage bosch/ingram type, it only requires small modifications and seems to be working OK.
    Alan
    Perth Western Australia
    2,678
    Default 505 alternator...
    Kimdeb.
    Go for a Bosch with built in regulator. Try for an alternator with the same or slightly higher capacity.
    Try your wrecker, they may have one for a late Falcon?
    con
    con is offline
    sydney, nsw, australia
    500
    Default 505 STi Alternator
    About six years ago, after being unable to find parts to repair my failed Motorola alternator, I replaced it with a Bosch BXU1285 with minimum modification. This 85 amp unit has an internal regulator and has been excellent. The only other change required was the warning lamp, which had to be replaced with a 2watt unit.
    con.....
    1000+ Posts silverexec's Avatar
    Melbourne, Victoria
    1,001
    Yep, I've gone with a Bosch unit too. A mate of mine who reconditions alternators had made up an 80A unit to originally fit into his Ford Escort. He hasn't got the car anymore but kept the engine and other bits. The unit fitted quite nicely into the Pug, but we did need to modify the lower mounting bracket to accomodate it.
    Richard
    - Richard
    Now: 405 SRI D70 '93
    - 2.0L manual
    Earlier: 505 GTi Executive '85
    - hence "Silver Exec"...
    25 GTX '86
    - manual conversion
    Feb 2002
    Tamworth NSW
    496
    Icon7
    Hi all,
    Thanks for all the replies. The Bosch type seems to be the answer, so I will investigate the BXU1285 etc. Will go to the wreckers with the U/S Motorola, and see what matches.
    As the original Motorola is 70 amps, I agree that opting for around 85 amps will make some sense, especially if I replace the viscous fan coupling with a thermatic type.
    Any ball park $$ figures for second hand or new?
    Kim.
    12,256
    Quote Originally Posted by KIMDEB
    Hi all,
    Kim.
    i think the last time i priced one from a wrecker it was about $110
    you will or may need to shim the bracket one way or the other for it to line up but that's not a big worry
    i keep looking around for one as one day i will replace the one on the 604 as it won't last forever and auto sparks chuck hissy fits if they see something come in that isn't bosch or the other common makes
    you should have seen the local bloke when i took a du sillier starter in to him a while back
    luckily i had a bosch starter that was exactly the same for him to put new bits in
    1 x '98 306 GTi6
    Feb 2002
    Tamworth NSW
    496
    Icon7
    Thanks Pugrambo,
    Yes, amazing the reaction sometimes when these people get moved out of their comfort zones (Bosch, Lucas etc).
    Still, the $$$ factor comes into it also, and, if I am to keep the car, then a Bosch alternator is probably going to be the best economic solution.
    Kim.
