205 Competition Parts
    1000+ Posts parry's Avatar
    Sydney Australia
    1,326
    Default 205 Competition Parts
    I am about to import some competition parts from www.shenpar.com if you need anything, we can save some money by sharing the freight cost. You can either talk to Bob of Shenpar directly and let me know as well.
    Shenpar motorsport provide very good advise on all suspension setup and engine mod advise.
    Example of Parts they have at their site.
    Peugeot 205 Competition Parts
    Con Rod bolt/nut - chrome/moly 18.00 ea.
    Sump Baffle Kit 145.00
    Uprated oil pump spring 5.00
    Oil Cooler Kit 130.00
    Piper 4 branch exh. Manifold 180.00
    Piper Exhaust System (stainless) 259.00
    Piper Exhaust System (mild steel) 198.00
    Magnex Exhaust Manifold /System 382.00
    Magnex Exhaust System (with H/R Engine Mount) 275.00
    Ashley Exhaust Manifold 150.00
    Ashely Exhaust System P.O.A.
    Inlet Manifold (Carbs/Throttle Bodies) 8 valve 130.00
    Inlet Manifold (Carbs/Throttle Bodies) 16 valve 165.00
    Engine Mounting Set (Hard Rubber) 88.00
    Solid Lower Engine Mount 35.00
    Ramair Direct Induction Kit 100.00
    Cerametallic clutch plate (200mm) sprung or solid 150.00
    Cerametallic clutch plate (16valve) sprung or solid 150.00
    Steel Jointed Gearchange Kit 5 speed 100.00
    Quaife L.S.D 490.00
    Gripper L.S.D 550.00
    Powerflex Anti Roll Bar Bush Set 21.50
    Powerflex Front Wishbone Bush Set 49.50
    Heavy Duty Front Wishbones 95.00 ea.
    Rose Jointed Adj. Front Wishbones 295.00/pr
    Gaz coilover,top adjustable suspension (adj.rear)kit 495.00
    Bilstein Tarmac/Gravel Coilover Kits P.O.A.
    Bilstein Front inserts Tarmac/Gravel 80.00 ea.
    Bilstein Rear Shock Absorbers Tarmac/Gravel 80.00 ea.
    Torsion Bars 20/21/23mm sets 300.00
    Rear Stub Pin Disc/Drum 30.00
    5 pos. Brake Bias Valve (lever / screw type) 65.00
    Brake Bias Pedal Box 220.00
    Hydraulic H/Brake Kit 48.00
    Fly Off Handbrake 33.00
    Aircraft Hose Brake Kit 10.00 per hose
    Roller Bearing Suspension Top Mounts 100.00/pr
    Quickshift Gearchange 45.00
    Vertical Handbrake Lever (WRC type) 100.00
    High gear steering rack 165.00
    High gear steering rack kit (splined or flat) 100.00
    Rose jointed Track Rod Ends 55.00
    Wheel stud conversion 48.00/set
    Polypropelene Sump Guard Kit 12mm 185.00
    Polypropelene Sump Guard Kit 6mm 130.00
    Polypropelene Tank Guard Kit 12mm 145.00
    Polypropelene Tank Guard Kit 6mm 99.00
    Solid Rear Beam Mounting Kit 35.00
    Fuel Filler Protection Plate 30.00
    Mudflap Kit 30.00
    Rear Shock Absorber Protection Flap Kit 30.00
    'Bike Carbs.' Conversion Kit 695.00
    FSE Fuel Regulator 65.00
    All Prices exclusive of VAT and Carriage.
    Top of Page
    General Parts
    Terratrip 202 Plus 149.00
    Terratrip 303 Plus 195.00
    202 Plus + Remote Disp 208.00
    303 Plus + Remote Disp 254.00
    Probes (any fitting) 21.75
    Clubman I/Com 79.00
    Clubman H/Set 24.00
    Professional I/Com 99.95
    Professional I/Com Headset 27.50
    Professional Practice H/Set 37.50
    Terralight VA 18" 25.00
    Terralight S 18" 25.00
    Proffes.Navig.Footrest 27.50
    Plumbed Fire/Exting 125.00
    Hand Held 2k Fire Exting 55.00
    F.I.A. Master Switch 24.50
    Twin Carb Throttle Link 57.50
    Silverstone 15"Gravel 80.00
    Silverstone Tarmac 15" 85.00
    Motordrive Club Seat 99.50
    M/Drive Pro Seats from 195.00
    'Bike Carb' Conversion 695.00
    90 205 Gti Cherry Red(Track Car)
    2009 207gti
    1985 505gti (Shitbox Rally) Sold
    PBs:
    Oran Park: 1:27:9
    Wakefield: 1:05.6 (July 2015)
    Eastern Creek: 1:54 (8v) 1:48 (16V)
    Mt Huntley: 34.44 (2004 stock 205)
    Ringwood: 35.06 (30/10/2005)
    Winton: 1:33.6 (2017)
    1000+ Posts tekkie's Avatar
    Jun 2002
    1,516
    what is your shopping list Parry?
    Sydney Australia
    1,326
    All the above
    2009 207gti
    PBs:
    Oran Park: 1:27:9
    Feb 2001
    493
    Quote Originally Posted by parry
    All the above
    Jun 2002
    1,516
    it would make your car rather heavy wouldnt it? its a lot of parts.
