water in side rear windows
Results 1 to 3 of 3
    Jul 2004
    nth balwyn, victoria
    1,428
    Default water in side rear windows
    in my gti ,if i go to the carwash and use the high pressure hose ,water gets in the back windows a bit.would getting new window rubbers fix this or is there an adjustment where it can be tightened more against the window rubbers.its no big problem but i would like to fix it.-BAZZ
    1000+ Posts Fordman's Avatar
    May 2004
    Perth/West Australia
    1,382
    Default High pressure water leaks
    In my experience working for new car dealers - manufacturers do not warrant water leaks caused by high pressure hoses - they just aren't designed for it. If the window leaks in the rain or while driving down the highway in the rain then fair enough, it needs to be fixed. You could replace the seals with new ones and still get water through with concentrated high pressure.
    You may have a problem, but I am just saying be aware that any window will leak with high pressure, so dont waste time and money unnecessarily.
    Cheers.
    Jul 2004
    1,428
    thanks for your comments.-BAZZ
