be-3 gear box?
Thread: be-3 gear box?
    Jul 2004
    nth balwyn, victoria
    1,428
    Default be-3 gear box?
    the haynes only has info on the be-1 and i need to know where the inlet is for putting oil/additives in the gearbox.
    looking at it if you took the wheel off,there is a bolt that has a head bigger than the rest and was wondering if this was it.it looks too low down though.-BAZZ
    Fellow Frogger! DejaVu's Avatar
    Sep 2004
    Croydon, Melbourne
    693
    ahhh off the top of my head, i think you are after a bolt that you can attach a size 19 spanner too.
    i got a good BE3 diagram from googles image search function.
    2013 Megane RS 265 Trophy
    7,448
    The plastic nut, under the battery tray.
    Jul 2004
    1,428
    actually i dont know what was up when i wrote the post cause its a be1 not a be3 i have and i found the drain/filler plug bolt which as a former person said is a 19 mm bolt on the part facing you when the wheel is off .i had been reading about be3 boxes prior to the post which is where the mistake originated from i suppose.
    anyway put some nulon g70 in the box and it runs so smooth now with no friction at all on gear change and hardly any crunch when engaging reverse first thing of a morning to reverse down the drive,and when a bit warm no cruch at all,truly amazing me thinks.-BAZZ
