bouncing speedo
Results 1 to 8 of 8
Thread: bouncing speedo
    auckland
    25
    Default bouncing speedo
    just recently my speedo has started bouncing instead of being smooth.
    it goes smoothly but sometimes randomly starts bouncing at about 110 - 120 and also alot around 40-60. sometimes at other speeds but not much.
    anyone know how i could fix this?
    thanks,
    dave
    Jul 2004
    nth balwyn, victoria
    1,428
    Quote Originally Posted by davey o
    thanks,
    dave
    this happens when the lube in the speedo cable drys out.now i reckon you should do a search on ther subject as if its done wrong,the lube travels up the cable and drips into the speedo /instrument cluster.
    a new cable will fix it and might be a better option,not cheaper but longer lasting soloution.-BAZZ
    auckland
    25
    i think ill just live with a bouncy speedo for now :p
    thanks for the reply, ill probably replace the cable a bit later on when i get some more money.
    Feb 2001
    493
    My 205 used to have a bouncy and noisy speedo at certain speeds... and it went away... but now i'm not too sure about the speedo's accuracy...
    Feb 2005
    27
    glad to hear i am not robinson crusoe with the bouncy speedo.......it gives me the shits, though i am taking some comfort in its being a common issue.......my 205 was imported from japan, and has only got 70,000 ks on the clock, so the cynic in me thought the speedo might be bouncing as a result of someones having a crack at winding the clock back - the cars in mint condition, so i suppose 70k is okay.........i think i'll live with the bouncing for a while.......not a cheap excersize to get a cable replaced, and there are so many other things to spend the loot on first!!
    8,395
    I once replaced a cable in a R12, and didn't follow the instructions on how to thread it around stuff.The resault was a very bouncy needle untill I got it right.
    Jo
    CitroŽn Tragic UFO's Avatar
    9,699
    The speedo in my D Special bounces for the first 30 to 50km of a trip, then the lube gets warmed up and the speedo needle becomes more realistic. Then it is the turn of the tacho to play "Am I reading full, half, or no engine speed". Keeps you alert on a long trip anyway!
    Moderator Alan S's Avatar
    Queensland, Australia
    8,923
    The problem they found overseas with these speedos is that we're all driving cars that were designed for LHD so as a result, all our speedo cables are about twice as long as the ones on a LHD car because the cable comes through the firewall on the LHS, bends to the right, passes though a pile of wires and ventilation ducts and then bends at right angles to connect to the speedo.
    I found on the BX that if I supported the cable onto the bulkhead just behind the speedo that it helped a lot particularly if I kept all stress off the cable but it still had a slight wobble in it. I had a visitor from the UK who had followed my pocedure but wasn't happy 100% with the result, so he took the speedo head, sprayed silicone release spray into the fitting on the back of the speedo head, worked it with a small screwdriver until it felt smooth and free and reckons his speedo is now solid as a rock.
    I haven't tried it personally, but if you've ever seen the drama involved in removing a speedo binnacle from a BX you'll understand why.
    Anyone doing a cable, I'd suggest you give it a go. Another guy had a cable made up by a company in Victoria and had it done about 75mm longer than standard; he reckoned that worked too, so perhaps a combination of all these tips may be the go.
    Alan S
