Fitting a 4 point harness to the RSC
Results 1 to 25 of 35
    1,160
    Default Fitting a 4 point harness to the RSC
    Just got a nice 4 point harness... (was going to get a 3, but advised a 4 is SOOO much better/safer)
    i can mount one strap in the orig rear seatbelt location... the other one is a bit tricky without moving a whole heap of plastic panneling...
    Anyone done this?
    is it safe to drill through the metal below the seats for the reinforcing plate?
    a bit worried, as there's a fuel tank down there somewhere!
    Fellow Frogger! casnell's Avatar
    May 2004
    Heidelberg/melbourne
    912
    Quote Originally Posted by nate
    Anyone done this?
    It shouldn't go lower than about 10deg.from horizontal or you get squashed...
    205gti
    1,160
    http://www.revolutionracegear.com.au...B5867C54B2FC02
    yeah 10deg recco, but 45deg max...
    i'm doing supersprints so its pretty "low risk"... & getting that 10degree is going to be almost impossible without a cage...
    Any ideas?
    There's no parcel shelf...
    May 2004
    912
    Any ideas?
    Can you put a bar from tower-tower like a strut brace? You can't in a 205 cos there's no towers as such but I've seen it done in lancers and soobies, then you can just fold the rear seats and hide it all...
    205gti
    1000+ Posts CHRI'S16's Avatar
    Jun 2002
    3,298
    Any ideas?
    Nathan, I have seen a low mounted harness in a slow (40Kph) hit at Oran park (last turn before main straight) snap the race seat in two, pushing some of it in to the back of the driver, he also thought supersprints were "low" risk... I'm just worried about your safety. - Chris
    ... ptui!
    May 2004
    912
    Quote Originally Posted by CHRI'S16
    I agree,I reckon I'd rather have a standard seatbelt than a harness mounted low, the vertical component is just too high at 45 IMO...
    Chris(also!)
    205gti
    1,160
    cheers mate...
    guess i'll have another good look at it tomorrow...
    maybe put a bar across the back or something...
    i.e. between the rear seat lock in points up top...
    Its odd, cause the harness guide (OMP) said use the back rear seatbelt mounts... which are VERY low...
    anyone know of any expert fitters?
    need to ensure there's no huge mods to the car though
    12,256
    what about the upper rear belt mounts ??
    1 x '98 306 GTi6
    1,160
    Too far apart... but i could put a bar between them!!!
    Ja bless!
    hmmm now all i need is a welder & some metal...
    555
    Ahah, a solution for the 205! :p
    Will keep that in mind when the time comes.
    1987 205 GTI - Graphite Grey - 206k km's
    1988 MR2 Supercharger - Mica Blue - 114k km's
    Jun 2002
    3,298
    Ja bless!
    Not really, if you put upper points to the drivers side upper belt point that would do it. In 90% of 4 point harness's each shoulder strap is independently adjustable. So just make one a little longer when you are adjusting them... - Chris
    ... ptui!
    1,160
    yeah both straps are adjustable!
    So one to the drivers upper & one to the upper rear?
    they'd both be on the right hand side of the car and not center... :|
    Cant go the rear left mount as it will barely be on the shoulder...
    Jun 2002
    3,298
    No quite... both upper straps will need to go to the upper rear left belt mount. Hence adjusting them indvidually. The lowers on will go to the coresponding belt point, the othe can reach across down to the other side. - Chris
    ps.. tis hard to explain without showing.
    ... ptui!
    XTC
    XTC is offline
    Mar 2003
    Location Location Location
    8,566
    Nate, I know of someone with this setup in a GTi180 .. recently done, recently passed CAMS scrutineering, there is quite a few tips and trick you might want to know. If so PM me.
    - xTc -
    Now this is a .sig
    Jul 2004
    nth balwyn, victoria
    1,428
    Quote Originally Posted by XTC206
    - xTc -
    please post findings as im also interested in a harness for the 205 and would like to see what comes up-BAZZ
    1,160
    OK well its finally in!
    I used the original mounting points for everything...
    the 2 lower ones either side of ma but, which needed slightly longer bolts (used high tensile of course), increased length so they are exactly the same depth
    Then the 2 shoulder straps i used the top rear right passenger mount. Once again increasing bolt length to ensure depth is the same.
    The only panel that doesnt fit back on is next to the orig seat belt clip (not buckle), but i'll order another one & cut it so the new strap fits (just a plastic cover).
    Took a bit, but WELL worth the effort!
    nothing modified! will post pics...
    I'll be doing the RCCA motorkhana day on Sunday, so i'll get the CAMS guys to go over it thoroughly & then post pics etc for all!
    -- Edit
    ummm legalities of using this on the road?
    since i've used original mounting points would it be OK?
    would i possibly have to use the original seatbelt as well?
    or is it engineer time?
    May 2004
    912
    -- Edit
    Congrats, sounds like a good solution. Would probably work well on a 205 as there's not much else to attach to without a cage...
    205gti
    1000+ Posts tekkie's Avatar
    Jun 2002
    1,516
    Harness is not a road legal restraint device. Does it have ADR compliance number on the plaque?
    I see no problems with the harness remaining in the car whilst driving on the road as long as the OEM seat belt is used. It would be a good idea to confirm this.
    1,160
    Chris, this will mean that in an accident it will try to push my head (or rip it off) towards the drivers window, as the straps are not directly behind me & on an angle...
    issues?
    would CAMS pass this? (have you seen a car with this setup pass CAMS?)
    --Edit
    The angle is about 20-30degrees... so if my high school maths isnt that bad, the force pushing ma noggin towards the window would be roughly 0.3-0.4 times the forward force... snapage of the head rest? hmmm
    1,160
    Well got the CAMS guy at the motorkhana to have a look at the mounting...
    Mumbled & ummmed & ahhed a bit & eventually came to a "i wouldnt really like to approve it"
    So the rear seatbelt mount aint gonna happen!
    Going to now put a bar (just some thick angle) between the rear strut mounts & put them on that... VERY simple & a lot better!
    Will post pics
    555
    So now all is lost for the 205 again!
    Damn, now i'm gonna have to get that rollcage.
    May 2004
    912
    Quote Originally Posted by Cubits
    I'm picking mine up saturday, I'll post pix if I can...
    205gti
    1,160
    Not all is lost.... spoke to the local guys at City Performance & he rekons he can fab something up between the strut mounts... about $800 out of Cromolly
    Anyone know any roll cage installers in North Shore area?
    Paul V able to Fab something up?
    555
    No, all is lost for the 205. You can't fab anything between the strut mounts on a 205, because theyre under the floor.
    Fellow Frogger! lucin's Avatar
    inner E melbourne
    453
    Rather than a bar, can you just lower the rear seats and put the eye bolt (with a backing plate underneath) into the metal at the rear of the boot? The bolt should be visible coming through where the spare tyre is?
    Then - 2001 206 Gti
    Now - 2000 306 Gti6
    Now - 1974 GS 1220 Club
