Megane 225 struts
Results 1 to 3 of 3
    Dec 2004
    yarraville/ victoria
    10
    Default Megane 225 struts
    Hi Guys
    Anyone can help with getting the front struts out of my Megane turbo its at The Mag wheel centre richmond (03) 94211266 and they cant get the suspension low enough to remove the front springs ..
    Apreciate any suggestions ..
    AL S2-225
    9,223
    The tool used for the R12 (etc) front springs might help...
    Sep 2003
    Boolarra Vic
    95
    Default Spring compressors?
    Surely it is possible to fit spring compressors to at least some of the spring to reduce the length of the strut. disconnect the lower ball joint. disconnect stabiliser bar links. remove the drive shafts. all are necessary on various pugs and I suspect Renaults are little different.
    Trevor Hoare
    Boolarra Vic
    '95 405Mi16 - what a great car! ; 89 405 ( for my daughter )
    previously 205Si, 504Ti, HR wagon with R16 seats, R16, R10, VW kombi, VW passat, HQ panel van, FB panelvan, Rover'49 P3 4-light
