STI powered 404
Page 1 of 4 1234 Last
Results 1 to 25 of 76
Thread: STI powered 404
    Jun 2002
    brisbane
    45
    Default STI powered 404
    Bonjour mes amis!
    At last I have managed to get some photos of the 2.2l 404 I'm constructing.
    Almost finished the engineering on the car.All we have to do now is finish the thing!If you go to www.peugeotech.com.au you will find some photos of the 404.Take a close look at the boot photo and see if you know where the A/C parts came from.
    19,211
    Default gti powered 404
    Quote Originally Posted by Chuck
    Bonjour mes amis!
    Hi Chuck,
    I'm restoring a 404 at the moment, but using a 505 carby motor which will later be warmed up.
    Did you have problems with gridlock between the the steering flector and the block ? I would be really interested to know what problems you had and how you overcame them.
    The air con fan/evaporator looks japanese, possibly nippon denso from toyota or honda possibly. Are you sure parcel shelf ducting system will cool the car.
    regards
    Rob
    r
    Fellow Frogger! 1pugnut's Avatar
    wollongong
    444
    very nice I am impressed I would like to know what parts were used to fit the hypoid diff I am thinking of putting one in my 404
    regards jamie
    series 2 405 mi16
    205 si
    series 1 205 gti
    series 3 205 with a gti6 motor project
    1970 404 ute 504 ti motor project
    parts cars 2 205 si's 306 sedan
    2004 206 gti180
    12,278
    Quote Originally Posted by 1pugnut
    regards jamie
    the trouble with a hypoid diff in a sedan is that the torque tube can hit the tunnel
    you either have to modify the tunnel or limit the travel of the diff or raise the rear end of the car to gain clearance
    1 x 2018 3008
    1 x 2000 Citroen XM,
    1 x '98 306 GTi6 sadly sold
    Jun 2002
    brisbane
    45
    Default 404 diff
    Yeah we have cut the tunnel and fitted a spreader piece to give us about 125mm deeper tunnel.I used 504L rear axle hardware purchased from another kind 404phile.We added 30mm to the panhard bar and the axle just sits in.With 504 standard rims only a small amount of body work is needed to clear the tyres.The torque tube and tailshaft had to be shortened too!
    Once I work out how to put new pics up I'll let you know.
    9,223
    Why not use 404 axles and axle tubes? Keep the wheels in closer to where they belong? It all bolts together... well, some elongation of the holes on the RH side, but that's easy.
    Jun 2002
    brisbane
    45
    Default 404 axles
    I have'nt tried to fit the 404 tubes as I wanted to increase the track,as we intend to get 200hp or so eventually.We are using the car as a learning project for the younger staff and will include chassis tuning into the project.
    Besides,a 404 with slightly flared guards should look nice.
    I will look at the 404 axles when I get the chance as I seem to recall my brother doing just as you suggested another life ago.
    12,278
    a 404 with slightly flared guards should at least take that straight lined flat look away from it
    might even put a little strength into those guards and we all know they need it
    a 404 with some style would be good to see
    1 x 2018 3008
    9,223
    They 'flare' naturally when they get a biff in the rear end...
    So I'd say they should stay straight to keep the back of the car up better (at least it would be some help), and they look right that way.
    12,278
    flare it, drop it, stiffen it
    good wide rubber under it
    it can only look and handle better then
    1 x 2018 3008
    9,434
    You would need to shorten the axle tubes if you use 404 axles and tubes. Otherwise the axles wont go far enough into the splines, a particular problem if you have a factory LSD.
    115mm eh, how far does the deepened tunnel extend for?
    I will be doing this on my 203, hopefully it won't need as much.
    Graham
    9,223
    Yeah, like the one on the north coast of NSW... needed three axle tubes to make two or something.
    I can't for the life of me imagine a 404 with flares looking any good!
    Jul 2004
    CLARE SA
    2,324
    Default Hypoid diff in 403
    Good fellows,
    this question of hypoid diff in earlier vehicles interests me.
    Commonly see comments re: spreader piece or raising rear end for torque tube clearance.
    What would be the minimum rear end raise to overcome this problem?
    cheers ed ge
    12,278
    just imagine this car with a little pumping on the guards to give it some shape
    1 x 2018 3008
    9,223
    But notice how much better it looks without that?
    12,278
    no......
    1 x 2018 3008
    9,223
    I do...
    12,278
    I do...
    hook, line and weighty thing
    your devotion to the 404 should go down in the pages of pug history
    1 x 2018 3008
    9,223
    Along with your penchant for purging the purity of Peugeot...
    12,278
    phhhfftt
    any mod to a 404 has to make them look better
    it was never a car that stands out from the crowd like the 403 before it or the 504 after it
    pity as it could have been a real good car
    1 x 2018 3008
    9,223
    All they ever needed was a fifth gear and a bit more grunt...
    Perth Western Australia
    2,702
    That 404 seems to be doing all the right things without the aid of flares.
    Although the 504 rear end? could be assisting. Note inner rear wheel.
    A 404 with flares ? Would be likened to a rat with a gold tooth!
    12,278
    Quote Originally Posted by Wildebeest
    i was wondering how long it was going to take someone to notice that seeing as it is the 2nd time i have posted the same pic
    no one picked it last time
    probably why it is handling so well
    1 x 2018 3008
    12,278
    a 404 was a good car in it's day
    the 504 is everything the 404 isn't though
    a 504 rides better and handles better
    i'd nearly go as far to say the 504 would stop better as well
    peugeots have always been renowned for their brakes so i couldn't see them going backwards from the 404 to the 504 in stopping power
    all my 504's had 604 brakes on them so that's an unfair comparison but i know my sisters auto 504 stopped very well even for a heavy auto
    1 x 2018 3008
    9,223
    I'd say it's obvious you have never driven a '69 or '70 model with the brakes working properly then...
