Volvo Manual box to suit V6
Page 1 of 3 123 Last
Results 1 to 25 of 64
    Jan 2005
    Melbourne, Australia
    9
    Icon5 Volvo Manual box to suit V6
    Hi guys,
    Just wanted to know if a 4 speed + OD box from a V6 Volvo would be beneficial to any of you and how much it would be worth. I'm not sure whether it would suit fitment to a Peugeot, and what anyone would pay for it. I've been told to make an offer for it, but am unsure of what to pay. Can anyone help??
    Dennis
    12,256
    the last one i heard of that was sold went for aorund $200 so that might give you a bit of an idea
    1 x '98 306 GTi6
    9,223
    You might find a Volvo buyer, but they might also need the flywheel and clutch assembly...
    It's too difficult to adapt to a Peugeot tail shaft/torque tube arrangement.
    12,256
    tailshaft is the easy part
    just making up the adaptor to take the torque tube is the time consuming and harder part of the deal
    1 x '98 306 GTi6
    Perth Western Australia
    2,678
    Default Volvo Manual Box to suit V6
    "tailshaft is the easy part". That would be the throw away comment of the year!
    To state the bleeding obvious, the Volvo has an open 2 piece tail shaft and the gearbox/overdrive combo would be a lot longer than a 5 speed Pug.
    To incorporate a torque tube to the Volvo box would amount to an operation of pyramid proportions.
    It would be more achievable to convert the Peugeot diff to an open tailshaft.
    With the amount of machining required to do it either way, must make you say to yourself. "Self, why?"
    12,256
    Quote Originally Posted by Wildebeest
    you don't need the volvo tailshaft
    you use the gearbox end of the shaft and cut if off and weld it to the pug shaft and have it balanced
    the pug shaft would need to be shortened but all that is easy and it has been done on many other cars over the years when adapting other boxes to them
    the hard part with the pugs is the torque tube which will need to be shortened the same amount as the shaft and then the adaptor welded onto the rear of the back of the volvo box
    this mod has been done to a jap box that was fitted to a 504 and has been talked about here before
    1 x '98 306 GTi6
    9,223
    Tunnel modifications would be required too... one reason I dismissed the whole thing...
    Especially with that bulky overdrive hanging out the back.
    2,678
    Default Volvo box to V6
    Pugrambo,
    I think I may? have got the gist of your idea. Once again I state the obvious.
    The Peugeot prop shaft has a male spline. The Volvo has companion flanges at the gearbox and propshaft. One has a firm press fit onto the rear of the O/D with a nut to retain. If you were to do away with this flange and weld a female spline onto the Volvo shaft would mean a lot of to and fro movement would occur inside the O/D.
    Also any welding around Mr de Normanville's aluminium overdrive would create problems within, as well as more oil leaks!!
    Both the idea of propshaft mods and my diff mod to a lesser extent have, to me, become exercises in what could be done but the big question still arises.WHY?
    9,223
    For the technical exercise?
    Shares in Castrol?
    To be different...
    12,256
    you could always make a gearbox xmember and have an open shaft
    you could also make the diff mounting more substantial as well if need be
    it would be an interesting excercise to do it but you are still stuck with a box that is still pretty rare so if something did happen to it you are going to be up the creek in finding parts for it
    better off staying pug or going down the jap road for a box or even a 5spd from a falcon or commode
    1 x '98 306 GTi6
    9,223
    There's even an outside chance that a BA10/5 could be found...
    I don't think the Volvo box would be all that hard to service. What did we establish? They sold 250 or so of them here? They'd still have parts, and the de Normanville stuff is readily available.
    How would you put a flange on the front of the diff, 'rambo? Or would you put some other kind of diff in there?
    12,256
    i thought it was 50 sold here
    a flange on the front of the diff would be easy enough
    cut the end of the shaft off and weld the flange on it
    1 x '98 306 GTi6
    9,223
    The pinion shaft?
    Or do you mean the tailshaft?
    Either way I see problems in a number of quarters...
    12,256
    The pinion shaft?
    either weld a flange onto the splined part that goes to the diff or weld the spline from the pug tailshaft to the volvo one
    nothing hard at all and these type of mods have been done numerous times as i am sure you have seen some in your travels
    i know i have seen a number of tailshafts modified over the years and when dealing with open shafts they are very easy
    nothing too hard about welding them, even axles have been welded up over the years when they have broken
    1 x '98 306 GTi6
    9,223
    Let's get this straight...
    We're talking about putting a flange onto the Peugeot diff's pinion so a tailshaft can be bolted up to it.
    What are you welding and where?
    12,256
    no, not at all
    i said to get the spline from a pug tailshaft and weld a flange to that
    or
    cut the flange off the volvo tailshaft and weld the pug spline to it
    nothing at all about welding anything onto a pinion shaft
    1 x '98 306 GTi6
    9,223
    I think you missed the point...
    This is the question I asked, and the one to which I've constantly referred since... got any answers?
    The flange has to be fixed to the pinion shaft somehow...
    12,256
    i'm not talking about weldiong anything to the pinion shaft of the diff
    re-read the posts
    1 x '98 306 GTi6
    9,223
    I read the posts, I'm wondering how you're fixing that flange to the pinion shaft...
    12,256
    not fixing the flange to the pinion shaft
    take the tailshaft and cut the diff end spline off as i said earlier and weld the flange to it as one option
    the other option was to cut the flange off the volvo tailshaft and weld the pug spline to it
    nothing at all i have mentioned mentions anything about welding or fixing anything to the pinion shaft of the diff
    1 x '98 306 GTi6
    9,223
    Okay, so how would you fix it to the pinion shaft?
    12,256
    how does a tailshaft normally fit in a car ?
    1 x '98 306 GTi6
    9,223
    To a flange that is fixed pinion shaft...
    That's why I am asking you how you would fix a flange to the pinion shaft.
    12,256
    pug diff doesn't move
    cut pug spline off pug tail shaft
    weld volvo flange to piece cut from said tailshaft
    1 x '98 306 GTi6
    9,223
    Yeah, you said that several times... but how are you going to fix it to the pinion shaft?
