do your 205 doors rattle?
    Jul 2004
    nth balwyn, victoria
    1,428
    Default do your 205 doors rattle?
    the doors on my 205 rattle a bit,i had the locks adjusted when it was in for panel work but this only helps a little.
    this annoys the hell out of me,i dont mind the creaky dash but the doors really gave me the irrits.
    last weekend i was given the remedy[thanks graham wallis]
    its called dry lube,it cots about $2.50 its in a stick form and is waxy to the feel.
    apply to door locks and catches and edges of lock and whalla,no more noises .
    im fargin wrapped mate.-BAZZ
    nJm
    nJm is offline
    Guru nJm's Avatar
    Jan 2002
    Melbourne, Australia
    2,930
    So do you spray this inside the door (on the whole lock mechanism) or is it for the external bits? Sounds just like what I need as the 505's driver's side door lock has rattled a bit loose as the door as drooped.
    Nick
    1983 Peugeot 505 GR
    9,179
    Quote Originally Posted by nJm
    DRY lube Nick, a bit like chapstick.
    Won't fix rattles due to loose parts but will fix the clicking and squarking you get from the teflon door lock surfaces when the body moves a little against the doors.
    Graham
    Jul 2004
    1,428
    i put it on the door catch and the white teflon[plastic looking]things in the lock mechanism.
    also a bit round the edges of door lock mechanism.
    it wont fix loose locks or incorrectly fitted or adjusted locks but will fix the rattles associated with the non slipping of the teflon parts that happen when the body twists and rubs against the door locks and makes door rattle and move.the noise is usually noticable on small bumps and non level surface driving.it sounds a bit like incorrect lock adjustment.-BAZZ
