Dual Battery System in 505 Wagon
    Fellow Frogger! Westair's Avatar
    Jan 2005
    Perth
    558
    Default Dual Battery System in 505 Wagon
    Hi,
    Has anybody put extra battery for car fridge etc in 505 Wagon?
    Will it go into engine bay or would special case in back be better.
    Advice appreciated.
    1986 Renault Fuego GTX
    1972 Mercedes Benz 280E
    1988 Nissan Trakka Campervan
    1972 VW Kombi
    In business, words are words; explanations are explanations, promises are promises, but only performance is reality.
    Harold Ganeen.
    Aug 2002
    1,290
    Havent put dual batteries in a 505 however have put them into my landcruisers. Considering that a 505SRDT takes a n70zz there should be room to fit some. Depending on $$ there are some small batteries that are suitable to deep cycle and have plenty of power for their physical size. Optima yellow tops and Odessy 1000 (Hawker Technologies) both spring to mind. Important things to consider are the charging and isolation systems. Isolation can be handled via simple marine style keys Hella make a big red one which rely on human interaction, the very thing that makes it cheap may also leave you with a flat main battery should you forget to isolate after sampling the contents of the fridge. Large 70amp solenoids work well with the ignition circuit energizing the solenoid and joining the batteries for charging while driving. Intelligent management systems such as the Piranah or Rotronics systems work very well as well. A good place to get info is your local 4wd specialist workshop as they will be very used to installing such systems.
    Neil
    '94 405 SRBT
    '82 CX 2400 Pallas 5spd
    '76 CX Super
    '05 WL Statesman
    '92 HZJ80 Landcruiser
    1000+ Posts CHRI'S16's Avatar
    Jun 2002
    3,298
    Jaycar also sell a DIY kit for auto battery isolation, they also sell all the little extras you will need, such as cabling, lugs, terminals etc. - Chris
    ... ptui!
    Jan 2005
    Perth
    558
    Thanks- I though Auto electrician that did 4wds would be way to go.
    Hope can get right battery in engine bay.
    1972 VW Kombi
    Harold Ganeen.
