Fuego Block to bellhousing Brace
Results 1 to 2 of 2
    Fellow Frogger! AU-YT's Avatar
    Apr 2003
    229
    Icon9 Fuego Block to bellhousing Brace
    On the Fuego There is a brace between the Block to bellhousing.
    Does anyone know the actual reason for this brace? I suspect it is to stop the bellhousing distorting But in which plane?
    I need to rework this to fit in a spaceframe chasis ( dont ask) and I was planning to replace the 1/4" steal plate with a 19mm Dia 2mm wall tube welded to the existing pressed steel mountwith extra braes in the pressed mount to ditribute the load.
    Perth Western Australia
    2,678
    Default Fuego block to bellhousing brace.
    Quote Originally Posted by AU-YT
    AU-YT.
    Your project sounds interesting, no, I wont ask.
    My theory is that because of the transaxle and the "wind up" reaction of the diff. could the brace be required to prevent a "hinge" effect between engine and trans.
    I like the sound of your proposed replacement of the dead weight steel brace with a lightweight tube buttress [?]
