lowering mi16 compression
    Member bj_dove's Avatar
    108
    Default lowering mi16 compression
    gday
    just wondering if anybody has experience with LOWERING compression on the mi16. as in can any height be taken off the piston crown safely? my local performance place said 8.2 to 8.5:1 would be good to run 1bar of boost on, and said not to even think about thicker gaskets or spacer plates, because it will cause detonation. how else can i get it down??
    cheers
    '91 Peugeot 405 Mi16 - only just run in......
    Fellow Frogger! WAUTY205's Avatar
    Jun 2004
    Devonport, TAS
    181
    Quote Originally Posted by bj_dove
    ... and said not to even think about thicker gaskets or spacer plates, because it will cause detonation...
    Detonation??? Maybe someone can fill me in, but I get the feeling they want to sell you some new low comp. pistons.
    Will
    1990 205Gti
    1976 504 rally car (currently out of action)
    108
    apparently if you decrease the compression by the way of a spacer or thicker head gasket it will cause detonation, because the squish area is increased in a square fashion, rather than the nice combustion friendly shape that is the standard sqiush. it does seem to make sense, but they are the first ive heard such a thing from.
    Perth
    130
    Have had detonation from a copper head gasket that intruded into the combustion chamber and made a hot spot but as long as it was no further in than the id of the liner wall can't see that there would be a problem. Thewy may be trying to snow you.
    Chris.
    108
    im doing a complete rebuild anyway, so if they are trying to sell me pistons, then good! some genuine low comp ones would be better than modifying anything.
    can anything be done with the head to lower comp.?
    cheers
