what engine?
Results 1 to 25 of 39
Thread: what engine?
    Dec 2004
    Kenya
    13
    Default what engine?
    Guys this is the deal, i want a faster, more powerful car. i've got a 1988 505 sr thats cool but too slow and thirsty. Now i've read the threads about modding and cold carbing and rejetting and now am more confused than ever. i simply want an engine thats more fuel effecient powerful and torquey than the 8 valver on my Peugeot. which engine will give me all these with the least amount of modification? i guess it has to be a longitudinal straight four mounted at 60 degrees to be as close to the current engine as possible but has to be injected and multi-valved for fuel efficiency. Please help me out
    19,043
    Default Wish List....
    Quote Originally Posted by adrianne
    Hi Adrianne,
    You post aptly describes what all of us would like: a quick fix to an existing Peugeot engine to double it's power output.
    Take my word for it: it ain't going to happen !
    Technical and performance forum gives tips and advice of what others have done to improve their cars.
    Have a look at Daves' site
    http://www.geocities.com/davemcbean/fiveohsindex.html
    Which discusses mods to Pug engines and fitting of non Pug engines.
    There is also a Peugeot project with Nissan(?) engine conversion.
    in the forum
    Good luck & best wishes in your engine works
    regards
    Rob
    Jul 2004
    CLARE SA
    2,324
    Hey Adrianne,
    unfortunately technology hasn't changed since your last post, the options remain the same and you either need to get to unerstand them or know someone who does, put you credit card in someone elses hands and get another motor adapted, or buy another vehicle.
    From memory, your vehicle when new probabley developed 105 hp, as it ages, runs out of tune it may only produce 85hp.
    Fit extractor system, open exhaust, add 10hp $400
    Fit thermo fan, add 5hp $150
    Fit larger carbie jets, add 5hp $150
    Fit cold air intake, add 2hp $100
    Full service, new plugs, points, leads, condensor, tune etc, add 2hp $350
    Total cost $1150, HP increase possible 24hp to 130hp, approx 25% increase in power at similar fuel economy.
    That is as good as the story get unless you start to modify the engine.
    Of course I know next to nothing of circumstances in Kenya and this may all be double dutch to you, or completely unobtainable, but it is the nature of the internal combustion engine.
    cheers ed ge
    9,223
    At least the proposed extra 24hp is all surplus power... that is it will be totally devoted to added performance as the existing power covers what the car's doing now.
    Dec 2004
    Kenya
    13
    All thats available here only its bloody expensive. And i think my car started of with about 80 hp not 105. will converting it to fuel injection help do you think? it costs about 1000 Australian dolooars or so (50K in the local currency) and whats the best fuel injection system for it single or multi port? what about fitting a coil to each cylinder and doing away with the distributor?
    Banned orestes's Avatar
    Sunshine Coast
    4,520
    i might be way off track here, so forgive me if i am... but why not look at the alloy block Mi16 and a BA10/5, somewhat dificult, but from what i've read baring driling a few extra holes in the bellhousing, i've heard that an Mi16 will bolt up to a BA10/5. Ofcourse, things like engine mounts etc, would have to be fabricated, but it would give you around 160hp with not much change in the weight balance of the car. it would also allow for a lot more engine modifications.
    12,256
    PRV6
    no need to say anymore
    135hp standard in good condition with plenty more to play with if need be
    1 x '98 306 GTi6
    Jul 2004
    CLARE SA
    2,324
    Orestes,
    That was Adrianne's first question on AF.
    At what price, hybridizing means engineering?
    How many people on this forum dealing with M16 Problems?
    Adrianne, what motor is in your vehicle now, how many kilometres, what condition is the motor in?
    You might be able to fit a PVR 6 for $1000, if your clever.
    Any power increase should be matched by optimizing braking, steering and suspension, another $1000.
    cheers ed ge
    Dec 2004
    Kenya
    13
    The engine i'am currently running has done about 60,000 kms but the last owner didnt take very good care of the car (He stuffed a piece of old tubing in the suspension arm in lieu of a bush!!) It is the 2 litre 8 valve push rod with a solex twin barrel carb. In other words bog standard. about that v6 i hear its thirstier than the four pot carbie
    Jul 2004
    CLARE SA
    2,324
    Yes, that is one of the prices of larger capacity motors.
    Jul 2004
    CLARE SA
    2,324
    You could easily exchange the solex carbie for a duel throat weber to achieve more power with better economy, add another 5hp to my previous estimates.
    ed
    Jul 2004
    CLARE SA
    2,324
    60,000 kms is very low, motor shouild be able to be sweetened up easily, full service and tune first. Adrianne it is very important that cars be maintained to give good performance. If you were to put a V8 motor in your car and didn't service it, in 60,000 kms you would be complaining about its loosing power.
    Jul 2004
    CLARE SA
    2,324
    You haven't said but I'm quessing your car is an automatic, it takes power to push these, especially in a relatively heavy car.
    These rear wheel drive Peugeots were built for long legged reliability, handling, comfort etc not powering around.
    9,223
    Hang on there a second, Adrianne...
    You mention sixty degrees... is yours a diesel? As in SRD?
    The petrol engine lies over at 45 degrees... with RHD it's nicer if it stands up a bit straighter than that.
    12,256
    even if it was a diesel it would still lean over at 45 but as he mentions a carby so i'd say it's a petrol engine
    the V6 in good form and tune should return high 20 miles per gallon
    1 x '98 306 GTi6
    Dec 2004
    Kenya
    13
    The car is a manual petrol driven SR. The Weber carb is a good idea and i will probably fit one in next week but i ask again would'nt changing the car to injection be better? Am guessing here but wouldnt i just have to change the intake manifold and buy an ecu giving me better power and fuel effeciency in one fell swoop?
    9,223
    You'd get better results if you used a fuel injection head as well... they have separate inlet ports.
    There would be a lot of them around there, I should think, with the Bosch K-jetronic injection on them. Adapting from there should be simple. A bit harder if you use the older Kugelfischer manifolds etc.
    1000+ Posts David Shearer's Avatar
    Glenroy
    1,141
    Icon10
    PRV6
    couldn't have put it better myself rambo. a V6 in a 505 is a magic machine. You always have the option for a turbo later too.
    78 Fiat X1/9, Peugeot 406 ST, Peugeot 407 V6 SW
    Previous:
    05 Megane Turbo
    2x 89 405 Mi16
    67 404
    Peugeot, Francais pour "Putain qu'c'est vite"[/FONT]
    9,223
    Originally posted by pugrambo
    even if it was a diesel it would still lean over at 45.....
    I thought it was fifteen... it's certainly not 45.
    Dec 2004
    Kenya
    13
    i think the fuel injected head is a great idea, ta Bell. Can someone walk me through the process of and parts required thereof to turn my gas guzzling 2 litre 8 valve solex carburreted 505 engine into an efficient fuel injected one without losing (hopefully gaining) power? we,ve got pretty decent mechanics here in Kenya but they tend to rip you off if you dont know what you are talking about so any help would be greatly appreciated.
    9,223
    You are best advised to get some bits off that K-jetronic model and then work from there... do a search in this forum for a thread about Megasquirt and you'll quickly work out some of the tricks and who to ask directly.
    From the K-jetronic engine you should get the electronic distributor, head and all the injection gear. Some you won't be using, some you will.
    Probably you'll look at getting a camshaft ground, so grab a spare to play with... others might advise you further.
    Nov 2002
    Yarrabilba, Queensland
    2,755
    Default Lhd/rhd???
    Hi Adrianne,
    You are i Kenya. Are your cars left or right hand drive?? If left, the turbo option would be relativly easy for you, as Puegeot had a turbo option for 505 in the USA (and Europe I think.)All this info is also on Daves sight, reffered to earlier. There is a guy here in Aus with a turbo engine for sale, so they are available, I know he imported it himself. Check E-bay, that is a good palce to start. RIght hand drive turbo conversions are more difficult due to the steering gear.
    Also, being a 1988 505, it most probably already has the fuel injection head fitted. Does the inlet manifold from the carburettor have 4 seperate branches? If so, you are part way there already. This would also be a good engine to use for a rebuild using a carburettor, because the 4 branch manifold is much more efficent and better flowing than the standard carb manifold fitted to early 505 engines. This manifold/head combination would work well with a weber carburettor, and a good set of extractors, that may get you out of the hole for a while, till you work out what you want to do next.
    Have fun.
    Chris.
    Previous
    2001 Rx-4 Privilege
    R17TL, 1973
    R20TS x 3
    R18 GTS wagon x 2
    R10
    Dec 2004
    Kenya
    13
    Our cars in Kenya including mine are right hand drive so the turbo option is out as for the inlet manifold its exactly like you describe and i have already identified a place where i can get a weber carb, just one question and forgive my ignorance but what is an extractor?
    Nov 2002
    2,755
    Default Extractors??
    Hi again,
    Sorry about that. I guess extractors is a term we use here in Australia more than most other places. I should have said headers. A good set of 4>1 headers, (exhaust manifold) would be a good match up for the weber and the 4 seperate inlet head. Did you look at Dave's site, he talks about camshaft modification also, and which cam profile works best with a particular head/carbie combimation. Fuel Injection is a complicated path for the unskilled or faint hearted and best left to the very committed.
    Cheers, Chris
    Previous
    2001 Rx-4 Privilege
    R17TL, 1973
    R20TS x 3
    R18 GTS wagon x 2
    R10
    9,181
    Quote Originally Posted by HONG KONG PUGGY
    Hi again,
    Cheers, Chris
    K -Jetronic XN motors are only really found in the USA where pollution laws are enforced. You could find a wrecked 504 TI and fit the engine and fuel system from that. This is easy and cheap as long as you are lucky enough to find a suitable 504 engine.
    As a further advance you could then convert this to electronic injection by modfiying the manifold to fit electonic injectors, fitting the various sensors needed by the EFI system and then install a cheap fuel only ECU.
    Graham
