Mi16 Power
Results 1 to 25 of 28
Thread: Mi16 Power
    7,446
    Default Mi16 Power
    After recently building an Mi16 engine for the new owner of my track car, I thought you might be interested in the results. This engine was basically stock, including ECU, with the exception of balancing, Stage I inlet cam and an increase in compression from 9.7:1 to 10.8:1 (via decking block & liners).
    You may recall from a previous thread that a fresh Mi16 with 9.7:1 and a Stage 1 inlet cam made 84kW at the wheels. On the same dyno, the engine above made an impressive 92kW at the wheels (ambient air temp 40 deg C). The air-fuel ratios at full load were around 12.8:1, meaning that the std mapping was capable of supplying enough fuel for the increase in power. Remapping the ECU would not make any more power. Further mods would require remapping however.
    I thought it was a valuable exercise that clearly shows how important compression is for an Mi16 engine to make decent power.
    Fellow Frogger! enthused!'s Avatar
    Jul 2004
    Sinney
    439
    so i take it this was 1.9 alloy block Peter?
    Can you explain how you raise compression without new pistons/liners?
    What is the process of engine balancing, is it a home job or best left to the "professionals"?
    Also... whens the website going live?? (waiting in anticipation)
    1992 mi16 1.9 litre - it's a love hate realtionship.
    whatever you do NEVER tell anyone your car is reliable. doesn't matter how much wood you touch!
    previous cars: peugeot 306xt, peugeot 205si, renault 20, renault 12 - sedan and wagon, renault 25, alfa 155 twin spark
    7,446
    Quote Originally Posted by enthused!
    Yes it was an alloy Mi16. The compression is raised by milling approx. 1.3mm off the top of the block and each liner. Not a job for the faint hearted. Owen Wuillemin did it for me. In addition to raising the CR, it also brings the piston flush with the top of the liner which reduces the squish height. This improves the burn rate (and effeciency) enormously, creating much better throttle response.
    The pistons, rods, crank, etc. were balanced at Duncan Foster Engineering. They weren't significantly out of balance from the factory.
    Without being biased, it's absolutely the sweetest Mi16 engine I've driven. Gone now
    Website? Soon.
    Jul 2004
    nth balwyn, victoria
    1,428
    Website? Soon.
    hello peter ,may i ask an inexperienced question?
    well here goes.,could the work you did on the mi 16 be done on a sereies 1 205 8v to sweeten it up a bit.? ie balancing and upping the cp in the same manner as you describe .-BAZZ
    1000+ Posts Dave's Avatar
    Apr 2001
    1,340
    Quote Originally Posted by bazgti
    8 Valve is easy to get compression from, just combine an early engine block with a late model head. Also its safe to shave 8 Valve heads quite a bit.
    Dave
    6,248
    You can balance the rods and pistons with an electronic scale by removing material down to the weight of the lightest one, but you need to know what you're doing so as not to weaken them (only the rods) or leave a stress point. I've done it on a Cooper S. However, the crank and flywheel you leave to be dynamically balanced by an expert!
    Peter, is there easily enough adjustment in the timing belt adjusters to account for the 1.3mm? I assume there would be, but I'll ask anyway.
    Stuey
    2003 PEUGEOT 206 GTi
    7,446
    Yes Stuey, there's enough room on the tensioners.
    As for the 8V. You can take up to 2mm off a DFZ 1.9L head which will give approx. 10:1, or better still, fit the DKZ head with smaller chambers. You'll have problems with pinging however, in the 2000-3000 range, if you don't fit mapped ignition or rework the distributor curve. That's the beauty of the Mi16. The knock sensor takes care of all that.
    Fellow Frogger! KRISKARRERA's Avatar
    Nov 2002
    England!
    134
    Shows how important good compression is on the Mi16 then. What's 92kw in bhp?
    405 MI16
    170bhp
    Le lion va de la force la force!
    Jul 2004
    CLARE SA
    2,324
    Multiply Kw by 1.3142 to achieve Hp. 121.
    Cal
    Cal is offline
    Moderator Cal's Avatar
    Jan 2002
    1,624
    Peter, I imagine there is no way to deck the head and liners while the engine remains in the car. In fact I can't imagine you could even do it with the short motor assembled?
    Cal.
    1995 Mazda MX5 - 2F Race Car
    1990 Mercedes 300TE
    1990 Mercedes 230E
    1977 Jaguar XJS V12
    1971 Morris Mini 1100K
    1967 Porsche 911S
    1957 Porsche 356A Speedster Replica
    6,248
    I'd say absolutely no way, Cal! It has to be milled on a milling machine in a workshop; you'd need to wash the block and liners thoroughly before reassembly.
    Good to see you back; there were some worries about you over in Asia with the Tsunami hitting.
    Stuey
    Perth Western Australia
    2,678
    Default M16 Power.
    Peter T,
    With the drastic work done on the block etc this would mean that the overall height of the engine would have been reduced?
    Were you able to [A] "catch up" with your cam timing by shuffling a tooth on the belt or[B] did you have a vernier adjustment on the modified cam pulley?
    Comment [A] was made with tongue in cheek !
    7,446
    Yes the block height is reduced by 1.3mm. It's done on a large milling machine. The liners are held on a mandrel and turned on a lathe to get the correct length/height - 0.003" protrusion. Not a job for the faint hearted.
    Cam timing remains std. as there are two pulleys, taking up equal slack.
    2,678
    Default Mi16 Power.
    Peter,
    I think we may be talking at cross porpoises regarding the belt and cam pulleys. Yes I can see that the belt run between the pulleys, with the timing marks observed remains the same.
    Now, with the reduced height of the block the belt run between the first cam and crank pulley would be slack. The only way to take up this slack would be to turn the engine clockwise. This would mean the crank pulley position would be wrong. To turn the engine back would in turn put the cams out of kilter. The belt tensioner would have no effect on this.
    7,446
    Quote Originally Posted by Wildebeest
    Peter,
    Yes it does. Reducing block or head height on an 8V (with a single tensioner)will retard the timing. Doing the same on a 16V (with double tensioners) has no effect on the timing. It is still possible to put all three locating dowels in, then tension the belt in the normal way.
    2,678
    Default M16 Power
    Thanks Peter.
    The operative word here is "tensioner-s". I wasn't aware that the twin cam engine had two. One on the 'back' side of the belt, the other on the drive side? Is this the norm on PSA engines? My thinking was clouded by FIAT and other twin cam engines both belt or chain who manage with one.
    brisbane
    47
    Hi Peter,
    What would you expect from the same engine in power gain with one of your stage 2 cam grinds and a programable ecu? You talk about a 3 angle seat grind? Have no idear what this is but did your engine have one done?
    7,446
    Quote Originally Posted by 405T16
    Hi Peter,
    The Stage II cam makes approx. 100kW at the wheels on the same dyno. That engine had bigger inlet valves, 10.4:1 CR and Haltech ECU.
    Cal
    Cal is offline
    Jan 2002
    1,624
    Quote Originally Posted by Stuey
    Stuey
    Yeah I didn't really think it could be done. Just thought I'd ask.
    Thanks for your concern mate. We were in Laos when it hit. We were supposed to fly to Koh Phi Phi after Xmas, but obviously changed our plans. A terrible tragedy for so many people. We were deeply saddened.
    Cal.
    1990 Mercedes 300TE
    1990 Mercedes 230E
    1977 Jaguar XJS V12
    1967 Porsche 911S
    brisbane
    47
    How much to do the inlet valves coming from a standard Mi16? Does that stage 2 cam grind give a lumpy feel and will it stall when idling? Do you have to have a slightly lower comp ratio with a programable ECU? And how does it affect the aircon system?
    7,446
    Not sure what that means.
    The other engine just happened to have 10.4:1, std. CR for the UK version.
    The Stage II cam is tad lumpy at idle, but very driveable.
    The ECU will deal with what ever CR you have. You program it to get the right AFR out of the exhaust pipe.
    It doesn't affect the A/C.
    brisbane
    47
    Sorry Peter I should proof read my messages before I send then. The message was suppose to say how much do the bigger valves cost to do and do you only modify the inlet side. Is that what the 3 seat angle grind is?
    The compression question was in regards to your engine comp of 10.8:1. This ratio would be fine with the bigger cams instead of 10.4:1? If you were to get a stage 1 grind can that cam be re-shaped for stage 2 or do you need a new one?
    How long does it take for you to do. I presume posting would be the best way of transportation
    7,446
    It's only necessary to do the inlet. The exhaust already flows incrediably well. When fitting the larger inlets, it's possible to cut a nicer 3 angle seat, that flows better than a single 45 deg.cut.
    The Stage I cam is ok with 9.7:1 and up.
    The Stage II cam needs 10.4:1 minimum.
    More compression is obviously better with both, until you reach the limit of the fuel you're using.
    No, there's not enough mat'l on the lobe to reshape a Stage I into a Stage II. The lobes would have to be built up, then reground, approx. $600.
    It takes about a week. Aus. Post is fine. They charge approx. $7.
    brisbane
    47
    What does raising the compression and bigger cams to do the torque figure?
    Would it be cheaper to just buy a new a cam shaft when you are ready to up grade to a stage 2 grind?
    The UK spec engines with their higher compression was that a result of slightly different block or was it different pistons that made the higher compression?
    7,446
    You don't get anything for nothing in this world. The same applies with torque. There is a slight decrease in low end torque, but an increase in mid range and top end torque. Thus the increase in power. Increasing the CR minimises the loss in low end torque.
    UK engines had different pistons.
