S16 Rattle from under the Hood
Results 1 to 7 of 7
    19
    Default S16 Rattle from under the Hood
    The S16 is in the wars again.
    Just recently ive noticed quite a loud rattle from under the bonnet somewhere. I believe its from lower down and thought i had traced it to the thrust bearing in the clutch. The rattle only occurs when I accelerate and gets faster in time with the acceleration.when i put the clutch in and slightly rev the engine, the noise still occurs which leads me to think its not the thrust bearing.
    Any thoughts would be great?
    cheers
    Tim
    12,256
    check your exhaust
    1 x '98 306 GTi6
    19
    Sorry for my ignorance, but check the exhaust to see if its loose or?
    thanks for your help
    2000+ Brad's Avatar
    2,404
    I think he is referring to the baffles in the Catalytic convertor, however these have not been known to be as much trouble with the S16's, just the GTI6's.
    So is the vibration proportional to the egine or road speed? Engine speed, I'd be looking at engine mounts, road speed, I'd be looking at wheel bearings, CV joints, drive shafts etc.
    19
    Yeah its definately engine speed, when i put the clutch in and rev the engine, the rattling increases. Ill check that too.
    cheers
    12,256
    i have a dead resonator in the GTi-6 that rattles as the revs rise
    i also have a clicking noise which we have found to be the mount for the exhaust
    these will be fixed when i get the resonator replaced
    the Mi-16 i had also had a rattle as the revs rose as well and that was fixed by fixing the mounts for the manifold
    1 x '98 306 GTi6
    19
    Ill check the resinator!
    Thanks for the ideas
    cheers
    Tim
