Window Washer Motor
    Fellow Frogger! pips's Avatar
    Dec 2004
    Behind you
    487
    Default Window Washer Motor
    Just bought myself a 405 Mi16. And loving every minute of driving it.
    But there are some issues with the car.
    The one I mainly want to ask about it the window washer pump (motor). Can this item be replaced by some universal (supercheap auto) part or will I have to go to a pug dealer to get the exact (albeit), overpriced pump.
    Can this be opened and the motor taken out? I ask this because I was taught to fix something before replacing it. And if (just by looking at it) the motor is the same variety I find at Jaycar or Dick Smith, I can fix this part for around $3 and my time, which I don't mind doing.
    pips
    Ever wonder why Mad Scientist talk to themselves? They know others just wouldn't understand.
    The software said "Windows 98 or better". So I installed Linux.
    1990 405 Mi16
    6,668
    pips, the choice is yours. I say this because mine had a universal pump inserted in the line with the original still there, and it worked fine. However, I repaired mine - see this thread:
    Mi16 Wiper Relay
    One thing I didn't mention in that thread (and which is important!) is that the lower bearing, which is a brass bush fixed on the shaft, running in plastic in the body and lubricated by the washer water, was jamming in the plastic housing because it was going too low into the plastic housing. This is probably through wear in the plastic housing.
    I fixed this by pressing a tiny, very thin brass washer onto the brass bush on the shaft, so that the brass couldn't jam in the lower plastic bearing housing. There's a step on the brass bit which holds the washer nicely. You'll see what I mean when you pull it apart. I used waterproof bearing grease for lube.
    Works perfectly now.
    Stuey
    2003 PEUGEOT 206 GTi
    Dec 2004
    Behind you
    487
    Cool
    I read the thread of yours. I also noticed that the washer motor get about 4V DC when its off, then 12.x V when I use it.
    I thought it was bizarre that there was 4V sitting there. But from what your refered to post says, this seems common.
    I'll just take the motor off and see what it is, based on that, either head off to Jaycar for a new motor or Supercheap for a universal pump.
    thanks
    pips
    1990 405 Mi16
    6,668
    pips, one reason to repair (or stick with original) is that the pump housing seals in a rubber grommet in the water bottle. I know it's an easy thing to get around, but original is neater.
    Stu
    Dec 2004
    Behind you
    487
    Oh, most definately.
    I come from a mechanical background where I was taught to fix something first. Then if nothing works, its time to consider replacing it.
    pips
    1990 405 Mi16
