BX 16 valve cylinder head questions
    Fellow Frogger! blahblah's Avatar
    Perth
    309
    Default BX 16 valve cylinder head questions
    The head gasket on my 16 valve has died ( overheating and oily odour from the coolant expansion tank - it was confirmed by a test for oil in the coolant).
    Are there any nasties to watch out for with this job?
    Any comments on aftermarket vs. genuine cylinder head bolts?
    What sort of cylinder head refurbishment should be done while it is off? (the car has coolant in it)
    Why does the overflow pipe from the coolant expansion tank point directly at the battery???
    The compression test was good (180psi or so across the board) so I think the rest of the engine is ok (It's done 168k)
    I've already discovered the strange coolant hoses with tee pieces moulded into them and that coolant distribution block on the back of the engine block. Oh, and that servicing a car involves only changing the coolant hoses that are easy to get to and are in full view in the engine bay... The hidden hoses all appear to be knackered.
    I think that some of the hoses and existing coolant steel pipes can be replaced with suitably formed stainless steel tubing (copper would be easier to work with...) to minimise failure of the hoses again.
    7,446
    Dear Blahblah,
    if it was mine, I would recondition the head while it's off. WA water is very bad so don't be surprised if you find some nasty corrosion, either on the head, or in the block under the liners. After all, if all was in order you wouldn't have a problem. You will need a VRS kit, new head bolts (aftermarket are fine) and you should replace all the hoses (both water and oil) while you can. Don't use copper pipes.
    12,256
    i have a VRS set here for a series one Mi-16 which i would say would be the same as the BX16
    i don't have any head bolts though
    let me know if you are interested
    1 x '98 306 GTi6
    9,223
    Very important that you don't use copper or brass pipes...
    Have a look at the galvanic scale and you'll quickly see why.
    12,256
    just have a look at a volvo block
    1 x '98 306 GTi6
    Fellow Frogger! Jack Z's Avatar
    Aug 2003
    Gosford, NSW
    302
    Chris,
    Peter T's spot on... you'll probably find corosion behind the liner of cylinder number 2.... well at least that's where I found it in mine and it had only done a documented 120k.... but guess what it was an Adelaide car... sh!t water.... and infrequent use over time the perfect breeding ground for corosion...
    So once you pull the head off, replace the gaskets and rebuild the head and then put it all back together again... (like I did) you will find a weak point or worse still crack in the block and pull it all apart again! OR you can bite the bullet and strip it all once and for all, rebuild the head have the block crack tested and do it right!
    Good luck with it all....
    BX TZI Hatch
    BX TRI Hatch
    GS C-Matic
