PRV K-jetronic sensor plate height
Results 1 to 3 of 3
    farmerdave
    Guest
    Default PRV K-jetronic sensor plate height
    In a downdraft K-jet sensor setup (PRV), should the rest position of the sensor plate be above, level with or below the narrowest point of the venturi?
    I'm getting conflicting information-renault specifies 0.5mm below, the Probst "bible" specifies above, and some say level. Currently the plate is set at the renault spec but starting is hard, thermal time and cold start are working fine.
    Farmerdave
    12,256
    Quote Originally Posted by farmerdave
    Farmerdave
    the sensor plate should be set from factory but if it needs to be checked or adjusted it should be sitting +- 0.5mm from the step in the venturi
    the other thing to check is to make sure it is central in the venturi
    this is what i have written here in the pug manual for the injection setup
    1 x '98 306 GTi6
    farmerdave
    Guest
    Thanks 'rambo, just needed to check.
    I checked an Autodata FI book for the Volvo specs, they are level to 0.3 below for "octopus" manifold, level to 0.3mm above for the twin rail manifold.
    I take it that the Pug spec works ok on your 604?.
    Farmerdave
