timing on a dizzy pack 405
Results 1 to 2 of 2
    Dec 2004
    dorset uk
    7
    Default timing on a dizzy pack 405
    i have found out the probelm with my fueling is actually the timing is out but what is it that tells the ecu how to set the timing as its all done automatically![]thanks for any help
    btw its a motronic 3.1 mapsensor jobbie!
    6,248
    The timing is controlled by the knock sensor and ECU. The ECU advances the timing until it knocks, then retards until the knock stops, in a continuous process. (The engine is at its most efficient as advanced as it can be without knocking.) Maybe it could be as simple as a bad connector on the knock sensor? This would usually just make the car feel like it's a bit flat, though, as the default is a retarded state.
    Stuey
    2003 PEUGEOT 206 GTi
