Help: 205 GTI Coil wiring
Results 1 to 2 of 2
    86
    Default Help: 205 GTI Coil wiring
    The previous owner of my 205 GTI broke the plug that plugs the main wiring loom into the coil. As a result of this, they plugged each wire individually into the coil as I dont know wheather the sequence is right. For those of you who have a SERIES 3 205, would you be able to have a squiz at the sequence of the wires on your car and let me know.
    Damien
    7,446
    There are 4 wires going to the coil, which connect to the -ve and +ve sides of the coil. There are 4 connections on the coil, 2 for each side.
    +ve side:
    pin 4 condensor
    pin 3 switched +12V (2A)
    -ve side:
    pin 2 wire from Bosch Ignition Module (3A)
    pin 1 tacho
