206CC replacement rotors
Results 1 to 2 of 2
    Dec 2004
    Perth WA
    1
    Default 206CC replacement rotors
    G'day,
    Just wondering if anyone has had any problems in fitting DBA's replacement rotors (slotted-type, part no. 274). I recently purchased replacements for the front pair (failure on my part to check all the dimensions in the 1st place) but the peugeot mechanic said that the DBA rotor offset was only 27mm and needed to be at least 35mm to clear the caliper. Salesman at the Perth Brake Centre confirmed the depth difference between the stock and DBA part. Consequently it appears that "my" CC can only be fitted with OEM parts. Not even the EBC catalogue had anything the right depth dimension. I am sad. Has anyone had a similar experience?
    Thanks for your comments.
    Fellow Frogger! Pug4eva's Avatar
    577
    You may wanna ask around 206GTI.net group on yahoogroups
    I was about to get those 274's till I read your post
    Hmmm
