405 bonnet-wont open...Hints??
Results 1 to 16 of 16
    brisbane
    2,898
    Default 405 bonnet-wont open...Hints??
    The latch at the front of the car has lost the wire from it so when you pull the bonnet release handle from inside...nothing happens. Thus i cant open the bonnet now to insert the little wire joey into the pull open handle.
    Any ideas on how to fix this??
    Cheers for any help on this as it has got me stumped. JR
    jr20516v
    Now:
    Exige SC [modded], 205 Si. 205 GTi , Megane R26 LY , Megane 225 [modded ]
    Previous: Honda EP3 Supercharged , 205 x34 [ including MI16 TURBO, 8v TURBO, CTI, 16V+TB's, 8V+TB's,] Fiat X1-9 X3, Beta coupes x5, Lancia Gamma coupe, GTI-R, Corvette C4, Fiero x5, Alpine GTA turbo, r5 GTT Dimma, 2cv ripple nose, Lotus Elise, 205 Dimma TT, Cliosport 172.x2, Clio rs 200
    9,223
    Any access from the underside? Or can you take out the grille and/or headlights?
    12,256
    the radiator would be sitting too close to the bonnet latch to get any access to it from underneath the car and even then there will be the A/C condensor mounted in front of it anyway to make things even harder
    as far as headlights or the grille in concerned if it is like the 306 then the bonnet needs to be open to remove these
    i went out and had a look at the 306 earlier when i read this post and i was trying to work out if there was another way even through the grille but the radiator support panel and thermo fans are in the way as well
    if i get a chance tomorrow i'll have a look at the parts manual CD"s to see what is and isn't there to see if there is a way around not having the cable attached but at the moment it seems to be a PITA situation
    1 x '98 306 GTi6
    9,223
    Maybe a case for designing special tool No. 23785674-94-81B then?
    6,248
    JR, I'll have a good look at mine today and try to work something out for you. Obviously easier when you can open the bonnet to devise a way. I hope...
    2003 PEUGEOT 206 GTi
    12,256
    here is a pic of the front end to maybe help out a bit
    Attached Files Attached Files
    1 x '98 306 GTi6
    9,223
    Any chance of changing that from a Word document to a picture?
    12,256
    can't you open it ?
    i could convert it if need be
    i'd have to convert the .doc to pdf then copy the pic in pdf and save as bmp then open the bmp to convert it to jpg and then resize if need be to host it then place it back in here
    let me know if you can't open the .doc and i'll convert it
    1 x '98 306 GTi6
    9,223
    Send it to yourself in an e.mail (ie copy and paste to the body of the e.mail... not as an attachment) and then copy and paste...
    This machine doesn't have Word on it.
    12,256
    converted for those who don't have word
    1 x '98 306 GTi6
    9,223
    You did a screen capture, right?
    Looks like a wire bent to hook onto that little lever on the bottom would do the job...
    Moderator Alan S's Avatar
    Queensland, Australia
    8,923
    Shouldn't really be a big problem; it looks exactly like the one on a CX and Brad's had a busted cable for years.
    He got an extra long phillips head screwdriver (about 600mm+ long) and from the drivers side, go in through the bars of the grille as high as you can.
    Sit the point of the driver against the hole that the cable used to pass through or against the nipple if it's still there, check that it's sitting there securely and then give the handle of the driver a short sharp hit with the palm of the hand.
    Remember, it has to be pushing in such a direction that it is putting tension onto the return spring so you have to both trigger the catch and place strain on the return spring at the same time.
    He had it down to such a fine art he could access faster than I could with the handle.
    Most important to use a spotlight to locate things so you know exactly what you are about to hit as there are plenty of other things that can be mistaken for the lever.
    Alan S
    12,256
    it's exactly the way it is in the .doc
    yes it is a screen capture then converted as i stated above
    anyway to get wire to it is going to be the hard thing to do
    i think the way Alan has described is about the best method as there are a few things in the way just like in the 306
    1 x '98 306 GTi6
    8,923
    All you have to remember is to try & keep the driver as close as possible to parrallel to the radiator; it's impossible to get parrallel but as near as you can.
    Meant to mention that on the previous posting, but I not very well today!! Biiiiiig night last night.
    Alan S
    6,248
    Had a look at mine. It's bloody hard to do. The only way I could get it was with a very long thin screwdriver through the bottom grille slat on the driver's side of the badge, angled at about 45 degrees upwards and towards the passenger side. You catch the bottom of the lever. It needs a fair push though, and I could only get it to work once. Remember to cover the screwdriver with electrical tape to stop damage to the grille paint. Oh, the bottom grille slat allows more angle on the screwdriver...
    Stuey
    brisbane
    2,898
    Cheers for all those handy hints guys...i'll give it a go. JR
    jr20516v
    Now:
