307 stud pattern conversion
Results 1 to 25 of 26
    May 2004
    22
    Default 307 stud pattern conversion
    I'm having a plan to convert the original peugeot stud pattern which is 4x108 into 5x112. The reason why i want to do it is because i'm getting an aftermarket wheels. Spacers or hub adapter would be imposibble as i know. Do you guys think that i have to modify the hub only or including the disc brake as well? Thanks...
    9,223
    Four to five is a no-no... especially with PCDs that similar...
    Get onto the boys in Canada and America... on the Peugeot-L Forum... they have made adaptors to use Honda wheels.
    Fellow Frogger! 505 to the max's Avatar
    Newcastle
    380
    Default Stud pattern
    Just out of interest Ray, would that principle apply to a 504/505/604 which uses the 4 x 140 stud pattern? That's a lot of room to play with if you wanted to use a five stud rim, regardless of PCD.
    9,223
    You certainly have less of a problem there... less prospect for conflict.
    But at the front I'd think you'd find it easier to adapt the hubs off a car from which you plan to use the stud pattern.
    12,256
    Quote Originally Posted by 505 to the max
    the ones that Ray is talking about on the other forum were made for the 504/505/604 4x140 stud pattern
    1 x '98 306 GTi6
    May 2004
    22
    How about 4x108 to 4x100 is that possible? Do you guys know where can i get the kit? Thanks..
    9,223
    As mentioned, the guys the other side of the Pacific... go to the Peugeot-L forum.
    12,256
    surely someone in this country is able to do something
    do we need to rely on another country for something like this
    1 x '98 306 GTi6
    7,446
    Why? We all love our distinctive 4 x 108 pattern. If I wanted 5 x something, I would have bought a Holden!
    9,223
    No, but they have done all the legwork... I have no doubt you could get working drawings from them to save a lot of hassle and research.
    I don't think anyone's going 5-stud, Peter...
    1000+ Posts CHRI'S16's Avatar
    Jun 2002
    3,298
    Quote Originally Posted by mrhusada
    I had adaptors turned (custom made), which will cover that convertion. For $340 a pair (thus double cost for 4 wheels) and adjusted offset too.
    If you get Simmons or ROH wheels they will have an offsett and studpattern to fit your car. - Chris
    ... ptui!
    May 2004
    22
    Quote Originally Posted by CHRI'S16
    Do you think how big the adaptors are? And are you in sydney area?
    9,223
    He is according to his profile...
    How much are Simmons Wheels these days?
    Jun 2002
    3,298
    Yep im in Sydney, the adaptors can be made to just about any size you like, but must keep the 4 stud to 4 stud ( or 5 to 5). So you can go to Honda 4x100 with a offset of about 28mm. But do you really want to d this
    Ray, Simmons are still very expensive, but you get a great genuine 3 piece wheel for your money.
    I'd be considering ROH, as you can order any size at no great extra cost. Some of their new desings are really good looking. - Chris
    ... ptui!
    9,223
    But how much?
    And you mention "$340 a pair" for the adaptors... do you really mean for four?
    Even so, I think this is fairly expensive.
    12,256
    But how much?
    with the labour involved plus the machining time i would expect to pay around the $100-150+ for each adaptor
    it's not a simple process and you still have to factor in materials
    the only way to get it cheaper was to get someone who has a machine shop that will give up their time to manufacture these parts
    1 x '98 306 GTi6
    Jun 2002
    3,298
    But how much?
    No they were 340 a pair, they were custom spun to get the stud patter and offest just perfect, they are also from a very light but stong alloy, plus they look a treat. 340 is expensive, but 1 off jobs ussually are. Or as pugrambo has just mentioned. - Chris
    ... ptui!
    9,223
    Well, I don't think so...
    Dave Mawer, for instance, does this kind of thing all the time. And that guy in the Blue Mountains who does the flywheels, he'd be equipped to do the same... their prices don't seem comensurate with that kind of price tag.
    It would cost next to nothing to cast up the blanks, it would mostly be the machining costs.
    12,256
    depends on the number that are bieng made hence i mentioned the prices above
    next time you have a spare minute or two give metaland or any other metal supplier a call and ask for a price on a lump of 120mm aluminium round bar or similar and sit down when you recieve the price
    then factor in time/labour plus the machine shop costs
    as a machinist who has done a few jobs in the past and keep my finger in the pie i can understand the prices and validate them
    machine work is never cheap unless it is a person who is running from home doing jobs on the side
    machines aren't cheap and profits need to be made to cover the cost of them
    1 x '98 306 GTi6
    Fellow Frogger! WAUTY205's Avatar
    Jun 2004
    Devonport, TAS
    181
    Are you buying new wheels? If so, a lot of wheel manufactures can drill them to your pattern in the factory. Although I'm sure not all style wheels can be.
    My brother ordered some new wheels & had them drilled to suit his car. If I remember right it was only about $25 per wheel extra. This would be cheaper & nicer than adapters I would think . But adapters would be the second best option otherwise.
    Will
    Fellow Frogger! Saru's Avatar
    138
    It's generally accepted among "fully sik" rotary owners that a set of 4 17x7" Simmons FRs with tyres will set you back about $2700 from Tempe Tyres. Tempe are clearly not making a lot of money on them as most places are asking more than $3000.
    I'm not sure about the cost of 16s as it would seem that it's 17" or nothing these days.
    Also, Simmons don't make 15" sizes anymore. They've outsourced that to "Retro wheels": http://www.simmonswheel.com.au/range.html
    '94 405 Mi16
    9,223
    So we still have no idea of the wheel prices?
    May 2004
    22
    Just wondering..if the wheels come with +42 offset, what is the correct size for the adaptors since 307 comes with +25 offset.
    12,256
    well i would say take off around $6-900 for tyres and divide the remainder by 4 and you would be pretty close
    1 x '98 306 GTi6
    Jun 2002
    3,298
    That's what you need a good wheel fitter for, they can work it out, it will vary on the type/make/model/offset you are going to. I know that certain shops sell direct fit wheels for 307's, just ring around and have your stud pattern and offset figures ready. - Chris
    ... ptui!
