Injector Cleaning
Results 1 to 13 of 13
    7,446
    Default Injector Cleaning
    I had some injectors cleaned today for an Mi16 engine I'm rebuildng. The process includes before and after flow tests, ultrasonic cleaning, back flushing, new filters, o-rings etc. Highly recommended for any EFI car that's done more than 100 000 Km. These injectors had done 145 000.
    Fellow Frogger! Rusty@'s Avatar
    234
    Purely out of curiosity, would replacing the injector nipples/nozzles be better??
    I got my injector nipples replaced and the engine is so much happier, but perhaps all I needed was an injector clean??
    Current: '06 Iron Grey 407 SV HDi '02 Silver Audi S4 '05 GTi 180
    Previous: '05 Aegean Blue GTi 180
    Previous: '04 Sahara Gold 206 GTi
    Previous: '95 Silver 405 SRDT (Fantastic Tourer)
    1,160
    More than likely a stupid question...
    Injector cleaner... does about as much good as racing stripes i assume?
    6,248
    Quote Originally Posted by [email protected]
    Sure it wasn't the pintles (or 'pintels' on Peter's receipt)?
    Stuey
    2003 PEUGEOT 206 GTi
    Sep 2003
    409
    and then there is ultrasonic cleaning where you dont really need to replace anything. It buzzes all the gunk out ?
    Sandringham
    41
    So has anyone had this done in Melborne who can suggest a place to get it done? I know alpine affair does it, but they cost $145, and id prefer not to pay that much if i dont have to...
    Thanks, Maca
    234
    can't have been the pintels as the entire job cost $800. That included glow plugs as well. The nipples were very expensive though.
    1000+ Posts David Shearer's Avatar
    Glenroy
    1,141
    Icon10
    Quote Originally Posted by Maca
    Thanks, Maca
    Auto Paris just got a cleaner and did mine as a test. I also ran some cleaner through the fuel and I drove to Wodonga early this week. I am getting around 1000 Kms to the tank in my Mi16. I want to believe the fuel gauge but with a different cam I am incined to be thinking wishfully. Either way hasn't cost me as much since the clean.
    Dave
    78 Fiat X1/9, Peugeot 406 ST, Peugeot 407 V6 SW
    Previous:
    05 Megane Turbo
    2x 89 405 Mi16
    67 404
    Peugeot, Francais pour "Putain qu'c'est vite"[/FONT]
    5,065
    Thanks, Maca
    I had some done at B & M Fuel Systems in Albert St. Richmond. About 25 to 30 each - removed from the car by me.
    It fixed a rough cold idle one one car.
    Jobo
    Jul 2004
    nth balwyn, victoria
    1,428
    thats about what it cost me to get mine done about 30 bucks an injector .you have to take them off yourself or get a mechanic to do it.
    they ultrasonicly clean them out then put new ends and adjust spray pattern.mine was hunting the idle all the time and generally not settling on idle.it fixed it right up.also dont run your tank low to help em keep clean.[that is if the pump takes it from the bottom and is not the floating type]im not sure whre my mechanic sent them to get done.-BAZZ
    Fellow Frogger! Tiop's Avatar
    Hunter Valley
    145
    yeah they cost me about $25 an injector when i remove them and take them in to be cleaned makes car run heaps better do it every 150 000km/h but if you only want to do it this often it is VERY important to change the fuel filter (new ones) every 40 000km this is what helps the most.
    That injector cleaner only helps and you have to keep buying it and using it,it is 5h!t. waste of money.
    Do it properly replace the fuel filters as ur meant to in the services.
    Ipswich, Queensland.
    1,888
    Cleaned and tested the injectors on the Alpine myself on a friends' machine today. Tested without cleaning, all had good spray pattern and within 4% of each other, worst to best on a pulsed test.
    I then ultrasonically cleaned them, back flushed, and tested them again to find they were all exactly the same in flow and that they had improved by approx 10%. I was impressed!!
    '56 Renault 750 (16TS Power)
    '62 Renault Dauphine Gordini
    '08 Renault Megane sedan
    Fellow Frogger! Jason20's Avatar
    Oct 2003
    Sydney, Australia
    439
    had my injectors ultrasonically cleaned, three out of four we're pretty blocked.
    made a huge difference, my engines idling normal again! feels 100% smoother now too! seems to have got rid of the K-light error I was getting also.
    I guess I should get a new fuel filter now aswell...
    1990 series 1, 405 Mi16 <-- Sold
    1998 Nissan 180sx TypeX, 2lt, rwd Turbo.
