Mi16 spark plug cables
Results 1 to 14 of 14
    Perth
    130
    Default Mi16 spark plug cables
    Whats a good quality set of HT cables that won't break the bank? (BX16V/Mi16)
    Chris.
    Jul 2004
    nth balwyn, victoria
    1,428
    Quote Originally Posted by Chris Dunham
    Chris.
    im about to change my cables on my 1987 205 gti,they are the original cables that came with the car.
    thats means they are 17 odd years old.not bad,
    im going to get the same ones again because they are copper cored as apossed to silicone cored.also have the spark plug moulded cap stopping dirt from getting in plughole.
    copper leads are more expensive to buy but as in my and most cases last a long time which is more economical in the long run. they are $98 from peugeot spares.
    this is 4 leads and 1 ht lead to coil.
    you can get aftermarket leads from about $29 upwards of the silicone variety.these leads are usually ok but tend to wear quickly.most auto shops have them.
    your mi 16 leads are similar to the 205 ones.-BAZZ
    Moderator Alan S's Avatar
    Queensland, Australia
    8,923
    Chris,
    You can get the original ones, Bougicord (sp?) which come with the special ends on to fit the recesses of the valley between the cam housings. They are square on the ends.
    I have heard of guys using Magnicore but whilst they may be good, they are dear as poison. One of the members of the BX16V club in the UK was getting them on a "mates rates" deal for around A$150 a set (plus freight and taxes in our case) but I got the Bougicords over for around $50 a set (plus usual taxes, freight and charges) from memory a year or two ago. I have seen the off the shelf silicone and graphite leads used, but in a 16V they tend o be both a bugger to fit as well as having the habit of shorting off all things conductive and make the car run like shit.
    I think you'll find that the motor Bazz is talking about is like the TZi which has seperate holes for each plug lead and with these you can get away with the off the shelf variety.
    When you replace them, also check and mark cylinders 2 & 3 as the leads are identical length and it's easy to mix them up when refitting..............and please don't ask me how I know!!
    Alan S
    Sandringham
    41
    I just picked up a new set of leads for my Mi16 today. Cost was $110. They are made by Top Gun.
    The idle now seems slighty less rough....but who really knows.... My old leads were the originals which lasted 140000 kms...
    Hope you find some cheap and decent ones.
    Maca
    7,446
    Find your local Magnecore dealer. They have the special spark plug boots. If you can't find a dealer in WA, contact Thundercords in Sydney. I had a set made up for $100.
    Thundercords
    U 2/ 20 Crescent St Granville 2142
    (02) 9897 3777
    Perth
    130
    Thanks one and all for the generous replies.
    Chris.
    1000+ Posts Haakon's Avatar
    May 2002
    canberra...
    8,747
    another reason I love the 406 - no leads
    Off the shelf Top Gun leads and other cheapies have always served me well - just ensure they dont touch each other, keep them clean (the engine bay should always be spotless anyway ) and routed appropriatly.
    9,223
    Top Gun seem to be (oh, the pun of all time...) a bit hit and miss...
    My brother runs a workshop on the Gold Coast and reckons that every time a car comes in with an untraceable tuning issue and it's got NEW Top Gun leads, changing the leads will fix it.
    12,256
    I have been running Top-Gun leads for years without too much trouble
    They can't be that bad seeing as i had them on a 604 that used to return very good mileage and all the TI's over the years as well that ran well
    Didi they have a bad batch at some time ?
    1 x '98 306 GTi6
    9,223
    No idea... I'm just passing on the observation of someone who works on a lot of cars...
    Jul 2004
    1,428
    Chris,
    Alan S
    mine are bougicord but i was referncing my 205 gti which i thought would be the same type of leads.rhese leads have a round plug on the ends-BAZZ
    Jul 2004
    1,428
    Chris,
    Alan S
    mine are bougicord but i was referncing my 205 gti which i thought would be the same type of leads.rhese leads have a round plug on the ends,
    do you have an addy on where you imported your leads from,ta-BAZZ
    8,923
    No sweat mate; the 205 and TZi have round holes at the front edge of the head whilst the 16Vs run in a valley between the cams and have these ginormous square heads on them that are as tight as a fish's to push down.
    I got mine from GSF in the UK.
    http://www.gsfcarparts.com/
    You can get current prices via the online shop without actually buying.
    Alan S
    8,923
    Bazz,
    FYI. From GSF online shop.
    T92610 IGNITION LEAD SET 205 1.9GTi >92; 14.50 U.K Pounds
    That gives you a guide as to price. This will of course be plus freight & taxes.
    Alan S
