raising a 505 waqen
Results 1 to 9 of 9
    Fellow Frogger! 1pugnut's Avatar
    wollongong
    442
    Default raising a 505 waqen
    I am going on holidays soon and the track where we are going gets a bit rough so I was looking at lifting my 505 wagen it is a 1991 model when I compare my wagen to sr or a gr mine sits lower I can get a set of sr springs if this will do the trick any idears
    regards jamie
    series 2 405 mi16
    205 si
    series 1 205 gti
    series 3 205 with a gti6 motor project
    1970 404 ute 504 ti motor project
    parts cars 2 205 si's 306 sedan
    2004 206 gti180
    Mar 2003
    Young
    121
    Go to a 4wd accessorries shop and get a pair of air bag spring helpers. They will fit inside the rear springs and can be pumped up to raise the height to what you require. It won't make it as high as a 4wd but it will make a big difference to your clearance when loaded.
    Nov 2001
    1,630
    Quote Originally Posted by 1pugnut
    regards jamie
    Might be a matter of tyre profile rather than springs I think Jamie. I don't think there was any change in spring height. However, I have rear springs from a 505 sLi if you happen to need them.
    Rod
    Rod's Home Page
    Rod's car page
    Peugeot 407 SV HDi estate 2008, Peugeot 407 SV Hdi Sedan 2006, Peugeot 406 ST (deadish), Peugeot 307 XSE, - Previously 403s, 404, 504, 505 sLI Wagons, 306 XSi, Renault 12, Citroen DSpecial
    9,223
    Yes, tyre profile might help on the rear...
    And airbags are a good idea too. At least you can let them down to a minimal setting when you don't need the height.
    Fellow Frogger! Phil Whitton's Avatar
    Bargo Sthn Highlands NSW
    273
    G'Day Jamie
    My suggestion:
    Pump up the tyres, leave the kids and baggage at home and enjoy, however if that fails rent a rally car or take my Peugeot badged courier and leave me the Pug. I'll make a ute out of it yet!!!!!!! Just kidding.
    How did the glove box go. I have a new paper one that I'll use for a buck and redo the box again.
    Nov 2001
    1,630
    First thing I noticed at the dealers when I bought my second sLi wagon was that they had fitted new 195/75/14's instead of the original 185/80's. It made a pronounced difference to the apparent height of the vehicle (the eye catches small differences in such things - the real difference in diameter is theoretically about 4 mm). Swapping them for the brand new 185/80 reinforced Michelins off my old wrecked wagon made an immediate difference in appearance, and enough of a difference in clearance to get over a local "front sway bar scraper" driveway without touching. I suspect the Michelins had harder side walls as well as a little more height
    With the 185/80's fitted the wagon has excellent clearnace really. I have driven mine extensively on fire trails and the like in East Gippsland without problems. Keep those rear pressures up if you have a load on. 45psi is about right.
    Rod
    Rod's Home Page
    Rod's car page
    wollongong
    442
    Quote Originally Posted by Warren Gordon
    not a bad idea i will look into it thanks
    series 2 405 mi16
    205 si
    series 1 205 gti
    2004 206 gti180
    wollongong
    442
    Quote Originally Posted by Rod Hagen
    Rod
    my wagon sits pritty level most of the sli and sr wagons seem to sit higher at the back I could be wrong I will have to look into it
    regards Jamie
    series 2 405 mi16
    205 si
    series 1 205 gti
    2004 206 gti180
    wollongong
    442
    Quote Originally Posted by Phil Whitton
    G'Day Jamie
    My suggestion:
    Hi phil thanks for the ideas I have not done any thing with the glove box yet
    regards Jamie
    series 2 405 mi16
    205 si
    series 1 205 gti
    2004 206 gti180
