504/5 diff identification
    Fellow Frogger! Janek's Avatar
    May 2004
    Sydernee
    200
    Default 504/5 diff identification
    i just purchased a diff, the seller claiming it to be a LSD, either 3.9 ratio or a 4.36 ratio.
    any easy way of checking?its in pieces atm, so numbers of the innards is no problemo
    -Janek
    Fellow Frogger! Jason Morris's Avatar
    Lower Hutt, New Zealand
    126
    Hi, have a look in through the four holes on the crownwheel carrier - if you see coil springs it's a LSD. Also, you could check the numbers stamped on the housing as detailed in attachments to this post...
    505/504 diff interchangeability
    Mine's still in bit's as of this weekend, two more shims to make!!
    Jason
    9,223
    Originally posted by Janek
    .....any easy way of checking? It's in pieces atm, so numbers of the innards is no problemo
    If it's in pieces, you count the teeth and divide the number of pinion teeth into the crownwheel number...
    Or you read the numbers off the front of the pinion shaft (9 x 37 etc).
    Fellow Frogger! 505 to the max's Avatar
    Newcastle
    380
    Default Diffs
    Pardon my ineptitude, but is an LSD actually stronger than a conventional diff, or just more suitable to gaining traction when putting power down?
    9,223
    Whether it's stronger or not depends on its construction...
    But principally its benefits are related to better traction.
