what say you...manifold swap...
Results 1 to 13 of 13
    1000+ Posts dino's Avatar
    Nov 2002
    4,569
    Default what say you...manifold swap...
    ...OK guys and gals......I d really like to dump the variable inlet manifold on the s16 for the earlier alloy mi16 or bx16v unit......I m sure there is nothing wrong with the variable unit.....but think of it as an experiment.....(i m thinking of mating a bigger throtle to it and don t want to go hacking into the plastic s16 manifold which I can always put back on)......
    Now what issues should i be aware of??? are the bx and mi heads identical through series and are there any differences in port spacings (I m not aware of any but better be sure).....Is one manifold better than the other....ie citroen versus pug (i tend to "like" citroen engeneering more so...but if exhaust manifold are to go by I m sure pug inlets must be well designed as well....
    Shoot away......any advice welcome.....
    One of the reasons I m experimenting here is to tidy up engine bay (aesthetically and reliability wise possibly) and possibly chase up better inlet supply in preperation for the upspec cam......
    Also......if anybodys got any 16v inlet manifolds lying around.....I d be very interested.....
    cheers
    dino
    Ahhh...before I forget.... what are the positives/negatives in regards to my inlet manifold swap idea....I m chasing a little bit more bottom/mid range torque.....
    Perth
    130
    Dino,
    I know didly squat about these engines but most variable length inlet systems are designed to provide maximum torque as well as top end breathing and it may counter productive to go to a fixed length system.
    I'm looking at inlet manifolds myself for a BX16v and it looks as though the Gti6 manifold would be a worthwhile improvement over my existing one - don't know if it would bolt up though?
    Chris.
    392
    Id be going the gti6 manifold, depending on price and availability.
    Im sure Peter T has some expereince in this area and will be able to tell you the pros and cons
    1000+ Posts CHRI'S16's Avatar
    Jun 2002
    3,298
    Dino
    I know of 2 S16's with GTi-6 inlet manifolds. They take a little work to get on but are a small improvement (mainly mid-top) over the S16 one. - Chris
    ... ptui!
    Member senthil16V's Avatar
    malaysia
    102
    Icon14
    Guys,
    How about using Peugeot 406 16V (XU10J4R) manifold? Are they identical to the Gti-6 inlet manifold? What kind of modification are to be done to when fitting these manifolds? Any difference in vaccum connections?
    Appreciate some feedback regarding this matter
    With Rgds,
    Senthil16V
    malaysia
    102
    Icon14
    Guys,
    How about using Peugeot 406 16V (XU10J4R) manifold? Are they identical to the Gti-6 inlet manifold? What kind of modifications are to be done when fitting these manifolds? Any difference in vaccum connections?
    With Rgds,
    Senthil16V
    7,446
    The XU9J4 manifold is not a straight swap on to the XU10J4 S16 head. The dowell locating pin holes are slightly different, but it definitely can be done.
    malaysia
    102
    Dear PeterT,
    How about the XU10J4R inlet manifold? Can it be fitted the XU10J4 S16 head?
    The problem here in Malaysia we never had the 306 Gti-6 or S16 ...and even the old XU9J4 were rare to come by ....for the XU10J4R we have plenty running around...
    so just wondering whether i can swap the manifold but reuse my ZX 16V throttle body...
    any experience with these manifolds peter?
    With Rgds,
    Senthil16V
    392
    Quote Originally Posted by senthil16V
    Dear PeterT,
    isnt the xu10j4r the engine in the gti6
    1000+ Posts TroyO's Avatar
    2,511
    GTi6 has XU10J4RS which has a different manifold to the XU10J4R.
    Troy.
    malaysia
    102
    Dear PeterT,
    Any ideas on this matter guys? Maybe PeterT can point us in the right direction...
    With Rgds,
    Senthil16V
    7,446
    I'm really not sure bewteen those models. If you were a betting man though, you'd have to say the inlet manifolds would be interchangeable.
    malaysia
    102
    Thanks for the info Pete...will experiment with the manifold and let you guys know whether its compatiable...from the picture between the XU10J4R and XU10J4RS they seem like identical...maybe the only difference will be a different throttle body...
    anyhow, all this confusion can be sorted out once i've experimented...will keep you guys posted...
    With Rgds,
    Senthil16V
