405 indicator prob
Results 1 to 8 of 8
    Jul 2004
    nth balwyn, victoria
    1,428
    Default 405 indicator prob
    my freinds 405 is giving him problems with the indicators .they seem to not work sometimes and after repeated on/off thet work again for a while.would i be correct in asuming that its the switch in the end of the stalk.or possibly a relay?-BAZZ
    brisbane
    47
    It could be an earth. Mine was doing the same thing only when the headlights were on
    May 2004
    Lismore/Brisbane
    74
    Mine had the exact same prob. Initially the dealer took it appart (the indicator stalk assembly) and had a fiddle, this caused the lever action to be very rough, and eventually the problem came back. It was eventually remedied by buying a new indicator unit including the stalk, havent looked back since.
    Jul 2004
    1,428
    Quote Originally Posted by 405dude
    hhmmm ,seems a common problem,ill check into it more ,thanx guys-BAZZ
    1000+ Posts David Shearer's Avatar
    Glenroy
    1,141
    Icon10
    Quote Originally Posted by bazgti
    Yeah my Mi16's indicators are acting a little weird lately too. Teh blinker goes reall fast on the left when the brake pedal is engaged and fine if brake isn't enagged. Weird stuff.
    78 Fiat X1/9, Peugeot 406 ST, Peugeot 407 V6 SW
    Previous:
    05 Megane Turbo
    2x 89 405 Mi16
    67 404
    Peugeot, Francais pour "Putain qu'c'est vite"[/FONT]
    Jul 2004
    1,428
    Quote Originally Posted by David Shearer
    sounds like the flasher can is getting too much voltage,check wiring and all earths,especially the stop light earth.-BAZZ
    Glenroy
    1,141
    Icon10
    Hi Bazz,
    can you help me a little. Sorry not a very good auto elec. How do I check the earths? Would it be in the talk lights or under the dash?
    cheers
    Dave
    Previous:
    05 Megane Turbo
    2x 89 405 Mi16
    67 404
    1000+ Posts tekkie's Avatar
    Jun 2002
    1,516
    Dave employ the help of a family member or friend for this test.
    run the engine normally, and perform the normal tasks that cause the blinker to misbehave. See if the rear lights do weird stuff, like fading, half lit, reverse lamps blinking etc.
    Those things are surefire symptoms of faulty earthing around the taillamps. It would also cause the problems you mentioned.
