205 brake ?
Thread: 205 brake ?
    Jul 2004
    nth balwyn, victoria
    1,428
    Default 205 brake ?
    are there any brake calipers from any other cars that will bolt straight on to a series 1 205 gti.im thinking maybe citereon bx16 calipeers,i know they run the same motor but not sure of brake set-up.
    what about 405 calipers or 306 calipers.would you have to change your rotors.?
    the reason im asking is you cant buy new 205 calipers anymore and im sure a second hand set would have wear n tear and need replacing again anyway,im about to rekit mine but im thinking maybe put up with it a bit longer and save for a new set if poss!!!
    mine have slop in them ,they klunk when braking in reverse when the pads slip,im told this is a very common problem with these cars.
    whats the soloution then guys!??!!?!??
    once again ta-BAZZ
    Sep 2004
    Tamworth UK
    618
    Default 205 brakes
    Why do I keep discovering people asking how to save the same problems I have!!!! My brakes do the clunk, drops the idle, and I was about to ask about top strut bearing replacement!!
    HELP
    1000+ Posts tekkie's Avatar
    Jun 2002
    1,516
    http://www.205gti.com/techbrakeconvUK.htm
    this might give you ideas. I think PeterT might have done something very similar to his racecar.
    7,446
    Unfortunately the brakes/driveshafts/hubs fitted to 75kW 1.9L GTi's were the same as fitted to the UK 1.6L GTi. So none of the bigger stuff fits. The UK 1.9L GTi's always had the bigger brakes/driveshafts etc.
    Jul 2004
    1,428
    Quote Originally Posted by kiwia110
    HELP
    its no coincedence,these cars are all heading for the 15-18 year mark and these are the general wear n tear signs associated with this model.
    top strut bearing replacement is about $140 a side for parts plus labour.
    pedders charged me $80 to put them in but they are mates so i got it cheap.
    you will also find that alot of the problems with the cars of this age have either to do with parts that contact or have bearings will wear with age and also anything with rubber as this perishes with age also .good luck ,
    -BAZZ
