Mi16 inlet cams
Thread: Mi16 inlet cams
    Perth
    130
    Default Mi16 inlet cams
    Has anyone tried Peters type 2 inlet cam? and is a 'streetable' option?
    Chris.
    Fellow Frogger! sproose16v's Avatar
    263
    Do a search for JasnoMi16 i think is his niickname. There are a few other people who have done it and its roughly a 15% increase in power. Good bang for you buck. PeterT also has another cam which has a harder grind and requires bigger injectors if you want to spend the cash and get the power.
    1989 BX 16 Valve Mk1 - SOLD (And Missed)
    http://www.bx16v.cjb.net
    1992 R32 GTSt Skyline
    Perth
    130
    Sproose16v,
    Thanks, I knew of Peter's first grind and it certainly sounds like a good thing, was under the impression he also had a more agressive version which I guess is the one you say needs higher flow injectors. Anyone used this cam?
    Chris.
    263
    I dont know of anyone who has used this harder grind. I was almost about to go ahead with a massive upgrade on my car but then there were a few problems i encountered with family and stuff and i didnt go ahead.
    I was hope to get at least another 50hp - 70hp out of the motor, ECU, Valves, Cam, injectors and Throttle Bodies. And then pray for an engineers certificate!
    PM PeterT or ask him for his number, im sure he would be more than happy to explain it to you or show you the specs on paper. His website is here if this helps: http://users.bigpond.net.au/taylor/p...cam_change.htm
