Constant Dim Charge Light.
    Nov 2002
    Yarrabilba, Queensland
    2,755
    Default Constant Dim Charge Light.
    I noticed tonight, the charge light is not going completely out in our 505 as I started it in the dark in the garage. I can just see the outline of the little battery symbol glowing at idle. I wouldn't have even seen it in the daytime.
    Bosch 55amp alternator,
    Appears to be charging, the volts rise to 14+ when car is running. High beam cuts the revs a little at idle just as lways, so everything appears to be normal.
    Indicator lights bring on the charge light to a brighter glow than the headlights alone do.
    Battery vgc, just new 2 mths.
    Belt tight and not slipping.
    Are the brushes on the way out?
    Chris L.
    12,256
    just check to make sure all the wires have a good contact first but normally the dim glow will get brighter as the brushes wear out in the alternator
    1 x '98 306 GTi6
    Nov 2002
    2,755
    thanx pugrambo.......forgot to mention I removed all wires , cleaned them, tightened the warning light spade lug too... and reattached.
    I'll get the brushes this week and change asap....should probably have a new set here anyway, same bosch alt' as some Renaullts.
    Cheers, Chris and ty again.
    9,223
    Maybe there's no rush... mine did it with new brushes anyway... it's been like that for several months, maybe 60,000kms.
    12,256
    if the slip rings on the armarture are worn then new brushes will give you the same effect
    1 x '98 306 GTi6
