URGENT help
Results 1 to 8 of 8
Thread: URGENT help
    Sep 2003
    116
    Default URGENT help...again!!!
    Hey guys, whilst drving tonight in my Xsara, the engine warngin light came on, then as I slowed down the accelerator stoped working so I turned the car off and on again and its been working since, about 30mins of drving. Ive looked in the manual and it says a problem with the emmissions, cat or ignition...anyone have a clue??
    Is it alright if I take it to a citroen dealer that Ive never been to??? Really worried about this as I have to drive to uni in Parramatta in peak hour tomorrow morning, its bout 40 min drive as well....
    WRC CHAMPS 04!!
    Sep 2003
    116
    thanks for your help guys, its all good now, for now I hope...
    WRC CHAMPS 04!!
    1000+ Posts TroyO's Avatar
    2,511
    Quote Originally Posted by Xsara VTR
    I had the engine light come up on my car a few times, with "Anti Pollution Fault" shown on the multifunction display. It was totally random, but fortunately didn't affect the operation of the car. In the end, the dealer replaced one of the oxygen sensors. It could be something as simple as an intermittant reading on one of oxygen sensors, or it could be any of the above. Best take it to a Citroen dealer to check it out, especially if you find that the accelerator stopped working. I suppose any Citroen dealer should be fine, unless there are any dealerships in NSW that any of you guys reckon should be avoided?
    Troy.
    Sep 2003
    116
    Same problem happened on Wednesday, so i took it to Continental Cars on Thursday morning. spent 2 hours there while they uploaded new stuff to the computer, and did sum other stuff. The car was working fine before I took it in and then after tehy poked around, its not revving past 3 grand so they said to keep it overnight and gave me a BX, what a shocker, lol.... But I got it back today with teh car in even worse shape than it was before, they cant figure the problem out an its not revving past 3000rev. They are Citroen specialsts and cant even work out the problem, he said that they will have to call france and ask them.......
    I am not really happy with the service now that the car is out of warranty and the car is even worse after tehy have messed around with it.....
    can anyone give me an idea what is wrong, im thinking its something to do with the computer after tehy have touched it.....they checked all the sensors and all is well with them....
    cheers
    WRC CHAMPS 04!!
    Moderator Alan S's Avatar
    Queensland, Australia
    8,923
    Don't panic mate; it's a case of "You stuffed it so you'd better fix it!!" as far as Buntings are concerned.
    Unfortunately, you did what most owners do when the dreaded light comes on...................PANIC!!!!!!!!! which is quite understandable, but remember, if the light comes on, it doesn't mean the computers stuffed; it means there's been a malfunction. Mine often comes on due to the voltage being drawn down by the starter motor. "Slack arse Al" hasn't got around to sorting the starter motor, so all I do is let it run for a while, switch off and restart and problem gone.
    I can't speak for a Xsara but on a BX there's a pin out test for faults that has been posted in common problems and fixes on this board and from it the cause can be pin pointed.
    Take a look there & see if that's any help. If not just give Mr B a kick in the coight and tell him to undo what he did so you're at least back to square one.
    Alan S
    Fellow Frogger! sproose16v's Avatar
    263
    Mate dont be gettn like that about a BX! Im sure it wasnt a 16Valve thats why you didnt like it!
    1989 BX 16 Valve Mk1 - SOLD (And Missed)
    http://www.bx16v.cjb.net
    1992 R32 GTSt Skyline
    Fellow Frogger! Janek's Avatar
    May 2004
    Sydernee
    200
    ive heard that a few times about those cars... seems to be a computer fault more often that any other hasrdware fault... odd
    1000+ Posts bowie's Avatar
    Aug 2002
    Sydney, Concord City, Sir.
    3,373
    computers. .ekk..
    would have that problem if it was a K-tonricly injected system.
