Hi all,
I'm Kenneth from Jakarta (used to live in Syd ).
Currently I'm looking forward to fit-in an old APEXi Super AFC for customize the air/fuel ratio at certain rpm, but unfortunately the installation guide doesn't include my ECU harness/wiring diagram.
My car is 1996 Pug 405 STi (XU10J2C engine) with Magneti Marelli 8P ECU.
The AFC needs to be wire to the vehicle's ECU harness :
- Power
- Ground
- RPM Signal
- Air Flow Signal
Anyone here can help me with the wiring from the MM8P, which cables to cut ?
TIA.
Kenneth
