Eibach Springs 30mm lower - $540 good price new?
Results 1 to 24 of 24
    Sydney Australia
    60
    Default Eibach Springs 30mm lower - $540 good price new?
    Is this a good deal? I got quoted $610 from a supplier in Sydney, this would be posted from QLD..
    1000+ Posts CHRI'S16's Avatar
    Jun 2002
    3,298
    $540 fitted would be a good price....
    Otherwise no not really, on the pricy side of a retail price.
    I had my 306 fitted with matched eibach pros on the front struts, revalved the strut, and reset the rear tortion all for $690.00..... -Chris
    ... ptui!
    Sydney Australia
    60
    That's not fitted, where did you get that done? What were the handling improvements like?
    Jun 2002
    3,298
    Had it done a while back at North Shore rally sport, the handling was tighter by about 15%, but this was combined with a 4 point roll cage, sticky tyres, brakes, car stripped out etc.
    I honestly don't recommed it, you are better of spending the money on Koni strut inserts, eibach springs, rear Konis and sportier rear tortion bar (or have a bigger sway bar somehow attached?)-Chris
    ... ptui!
    Member ParanoidAndroid's Avatar
    111
    Yeah thats about what they cost. Around $550 for the Clio but put delivery on top of that and its a fair bit more obviously. There are two kinds. If I remember correctly there is sportline or pro. I think the pro kit is 25% stiffer, the sportline 35% stiffer. Dont take any notice of how far they say it will lower the car. I think the figures they quote are for a normal clio rather than a sport so it wont be lowered as much on your car. It can also vary a fair bit from car to car and will take a while before it beds in and reachs its lowest point.
    I have the sportline (the harder ones) and my car went down 10mm all around which was all I wanted. Its about handling rather than lowering. Expect to shell out around $250 for fitting. You will need a front alignment. I dont think they can do one on the rear. Make sure u go somewhere reputable.
    Josh
    Fellow Frogger! Janek's Avatar
    May 2004
    Sydernee
    200
    allsprings.
    they custom make them. should set you back about 200 a pair... from memory they were either 140 or 240 a pair, but dont remember exactly.. ill chase up the number and prices for you. they custom make them to either stock, lowered or your custom specs, just make sure if u give gustom specs, u give them all the details
    -Janek
    Sydney Australia
    60
    Cheers.
    Josh - What's the ride quality like with the sportline Eibach springs? They say that the pro-kit springs retain excellent ride but then the stifness ramps up pretty dramatically when you push them..
    111
    Not too different to normal. A little bumpier as you would expect but not jarring by any means. Thats the reason i wanted them. They improve the handling a fair bit but dont change the ride too much or make an already low car too low. Theyre variable rate or dual rate springs so that would make sense that they ride quite well but are hard when u push them.
    Search for posts about them in cliosport.net there is tonnes of info.
    Says here that Eibach's Australian warehouse is in Sydney so hopefully you wont have to have them sent from Qld. Have a look for a contact on the website.
    http://www.eibach.com.au/page27.html
    Josh
    12,256
    Quote Originally Posted by Janek
    allsprings.
    -Janek
    allsprings ?
    in liverpool/moorebank ?
    used to be jumbo springs ?
    i had them in a 504 and they were pretty good
    what they are like for newer cars i don't know
    1 x '98 306 GTi6
    May 2004
    Sydernee
    200
    yes, thats the one pugrambo... theyre jumboz by allsprings.. did a fantastic job for my mazda... rally spec (tho its still a boat.. damn FWD)
    -Janek
    May 2004
    Sydernee
    200
    i'd just like to take a moment to mention i'm cllimbing to my hundreth post how cool!
    XTC
    XTC is offline
    Mar 2003
    Location Location Location
    8,566
    Not by posting one after the other though .. only counts as one I'm affraid.
    Oh humour posts don't count either ...
    - XTC -
    Now this is a .sig
    May 2004
    Melb
    75
    i'm looking at a eibach pro kit too....$550, fitted. Are they really any good? Bare in mind its a gti 6 so improvements are scarce.
    1000+ Posts Luca's Avatar
    Mar 2003
    1,335
    I paied about $550 for the pro kit about 2 years ago... that's fitted by car shine here in Melb.
    May 2004
    Sydernee
    200
    Quote Originally Posted by XTC206
    - XTC -
    mine have all been technical except for the two in this one WIN!
    Sep 2003
    116
    how much would it be to fit prokit spings to the front??
    is there need to upgrade the shocks as well?
    and by how much would the car be lowered (for a xsara)?
    WRC CHAMPS 04!!
    Mar 2003
    1,335
    Depends how much u're mechanic charges per hour and how slow he works.
    U can keep u're existing shocks. (they do sit lower in the oil well)
    The car comes down between 30-50mm
    Sydney Australia
    60
    I'm getting some Eibach pro-kit springs installed just as soon as I can, should be fun. Then I'll do an advanced driving course.
    Tadpole Sil S16's Avatar
    12
    I got quoted well under $400 for S16 30mm lowered Eibachs from Wholesale Suspension in Penrith, where I also had the rear torsion bars reset.
    1995 306 S16
    Fellow Frogger! Reno's Avatar
    1,260
    Eibach Spring prices vary from car to car.
    Clio's obviously seem to be more expensive then others.
    Sep 2003
    116
    Quote Originally Posted by Sil S16
    might have to give them a call, do you know if they have a website or have their phone number??
    WRC CHAMPS 04!!
    1,260
    i bought Eibachs for my Xsara from www.hardingeuropean.com were about $300(ish) keep in mind you only need 2.
    speak to Guy Harding their
    Sydney Australia
    60
    Got quoted $850 fitted and wheel aligned, anyone know anywhere cheaper in Sydney?
    Sep 2003
    116
    This is what Ive been recently quoted....
    Front Springs $300pr
    Labour $300
    Wheel align. $80
    Total $680
    This is for 30mm lowered and including adjustment of rear torsion bars.
    WRC CHAMPS 04!!
