Modifications: PRV v6: turbo?
Page 1 of 3 123 Last
Results 1 to 25 of 62
    Fellow Frogger! Janek's Avatar
    May 2004
    Sydernee
    200
    Icon10 Modifications: PRV v6: turbo?
    Ok, so I have sourced a Volvo b280e engine, computer and wiring harness/loom... complete engine incl alternator, exh pipes, even air con pump (which I am going to remove).
    Itís an even fire, MPFI model, good nick (though I think will be rebuilding)...
    Now... for the fun stuff... as this is all going into my 504, a few things Iíd like to know... for one, turbos... I have also sourced a pair of brand new t3 turbos at very reasonable prices, though I have not bought them yet, as I donít know if theyíre big enough, the difficulty of adapting them to my engine, and in reality, I know nothing of turbo charging cars, will I need to get diff pistons to lower the CR? Any help in the turbo department would be much appreciated... the whole turbo thing has always interested me, but a lack of capital, and experience with any sort of turbo has stopped me.
    As for the 504, I have already started on the brakes (have fitted '82 504 struts, and am sourcing some 264 brakes... thanks pugrambo), and have pulled out the engine.
    The 604 cross member shouldnít be too hard to find, but ill let post a wtb if I canít find one. In any case, it will be at least 6 months before I get it on the road... I want it all to be as close to perfect as it can be.
    Now, sticking to the engine, as thatís what this post is really all about... I will be pulling it apart to bare nothingness, inspecting, honing, machining, and replacing all that I need... I just got quoted a scary and ridiculous sum of 350 for a vrs kit... anyone know where to source one for a reasonable price? Or for that matter, any parts for it for a reasonable price?
    So... mods I plan to do...
    Bottom end
    New bearings
    Renew/freshen everything
    Head
    Port/polish
    Clean up
    Machine
    Camshaft
    As suggested, will contact crow cams for a nice cam
    Turbo
    2x t3 turbos, running a nice, not crazy boost
    Extractors/exhaust manifold
    Any ideas?
    Exhaust
    Straight through 2Ĺ or 3 inch
    looks like its going to be plenty more before its all done, but its well underway now!
    Janek
    May 2004
    Sydernee
    200
    ps. oddfire, i have read through a lot, if not all of your posts, and have carefully spent time considering my question(s)...
    as such, i know you said stick with the 2.8 oddfire, with 604 head and carby, but i'd like the efi. and i like the sound of a slightly more modern engine... atm its mainly about the turbo, but help all round would be nice
    9,185
    Quote Originally Posted by Janek
    Bottom end
    New bearings
    Head
    Port/polish
    Clean up
    Machine
    Camshaft
    Turbo
    Any ideas?
    Exhaust
    Janek
    Sandwood in Melbourne is very good for Volvo parts.
    I would get the thing going first, forget the turbos for the time being, particularly as the motor is in good nick. You'll find that even the timing chains and tensioners will cost lots of dollars (if you can source the parts).
    What compression ratio will you be running? If you use the standard pistons there is likely to be far too much compression after it is turboed, one of the reasons oddfire is running his on LPG.
    Graham Wallis
    May 2004
    Sydernee
    200
    i dont know what CR im after exactly, but i think close to 8:1 is a reasonable figure... im looking at 10lbs boost...
    ive heard talk of some pistons from a ford? that fit pretty much straight in, though i dont know much about any of this...
    i'd really like to find somewhjere i can source the parts for realtively cheap, but that may not be possible
    Brisbane/Australia
    2,051
    Head
    Port/polish
    Clean up
    Machine
    Janek
    Volvo recommend that you do not machine the heads on PRV V6. In fact, recommend is too mild a word, they say you musn't machine the heads under any circumstances. Could be a ploy to make people buy new, extremely expensive heads (would a car company do this) or it could be true. I don't know if this applies to the earlier B27/B28 motors only. What does Peugeot say about machining the heads on a PRV V6?
    Also, wouldn't a VRS kit for the Peugeot motor of the same capacity fit the Volvo motor. The block would be the same but the heads might be different but as long as the water galleries are in the same place they should be a fit.
    Ren
    farmerdave
    Guest
    Quote Originally Posted by REN TIN TIN
    Hmm, Renault have the same instruction in their MR manuals, applies to 140-144-z7v-z7w-z7u series engines (early to late production). Does anyone know if there is a technical reason for this? Is there any firsthand knowledge out there?
    Interestingly they give a tolerance for head height (which is about 15 thou from memory) which suggests that if a head was unpitted and had been heat straightened it could be carefully resurfaced and remain in tolerance.
    Janek, how can you prefer the even fire to the odd fire exhaust note especially with a big straight through exhaust......
    Farmerdave
    May 2004
    Sydernee
    200
    because i know nothing of the oddfire note, and only have access to an evenfire engine.. ps i like the idea of efi
    Simon's Avatar
    6,162
    Quote Originally Posted by farmerdave
    Farmerdave
    My thoughts on the no machining rule on both the Douvrin OHC 4 and PRV V6 motors is that the factory may find the timing belt and chain tension critical items. You machine the heads, you place the chain/belt auto adjusters at the extreme ends of the travel once the car has a few miles under its belt, possibly leading to jumped teeth towards the replacement life of the chain/belt. Having a no machining policy means that the owner would not be able to complain to the factory in the case a car jumps a timing tooth with a machined head/s.
    Also on the V6, the intake manifold will have to be machined to suit the machined heads, otherwise it may not fit.
    Brisbane/Australia
    2,051
    Quote Originally Posted by Simon
    My thoughts on the no machining rule on both the Douvrin OHC 4 and PRV V6 motors is that the factory may find the timing belt and chain tension critical items. You machine the heads, you place the chain/belt auto adjusters at the extreme ends of the travel once the car has a few miles under its belt, .
    The story I heard was a variation on this. Namely, with the timing chain tentioners at the end of their travel, it diverts oil away from the cam leading to accelerated wear.
    Don't know about the inlet manifold but the holes on the front timing chain cover allegedly won't line up any more resulting in leaking. I find this hard to believe that skimming say, 5 - 10 thou is going to make any difference to the bolt holes lining up.
    Ren
    Fellow Frogger! OddFireV6's Avatar
    152
    All: Iíve said this many times, year for year PRVs irrespective of manufacturer the castings are identical and interchangeable except for he lower sump of the Renault/Delorean and FWD cars. So for the same capacity head gaskets are interchangeable.
    Heads can be machined Iíve done it many times however some issues can arise. You can get valves hitting pistons depending on lift and you may need to skim the timing cover so the rocker gasket has a level surface. I have never had chain tensioners come out on any of my engines and the failures I have seen are where the plastic came off the curved chain guides. With head machining the inlet manifold mating does not suffer. The head ports are way bigger then the manifold port and so allows lots of room for movement, I have never machined a manifold and advise against it.
    Janek Janek Janek you have much to learn.
    Well OK or as you start most of your posts ďOK wellÖ.Ē Let me start with a basic assumption that you do not gain any pleasure with burning cash, if I am correct in this assumption can I give some advice. Lets go point by point.
    You have a B280, this is good, well done, do you actually have it in your possession? If you do immediately remove the spark plugs and oil up the bores, they rust easily, also drain all coolant from the Block.
    You do not actually have the two T3s and this is good because they will probably be too big although you did not say what trim or size or exhaust and compressor housings you will use. I can advise based on first hand experience that twin T2s T2.5s, TD04Ls are plenty big enough, Iím taking a punt on T28s with small exhaust housings which may yet prove on the big side. Laggy big boost turbo cars are a pain in the arse, a couple of T2s will laglessly punch you away from traffic lights and still have big power at the top end,
    Why would you buy new turbos, this is extravagant, get some cheapies from John Verban or a wrecker, even if you get a few dungers this is better than spending $2k to $3k on newies. My T28s from John Verban were $250 each and they are in good condition. Iím using T28s because they are cheap. Save this cash for the construction of manifolds and head work.
    Its often not necessary (this is based on experience) to replace everything with new bits, in fact since you may get greedy with boost and blow it up a few times you should simply apply good engineering practice in the engine rebuild. New parts are seldom an enhancement to performance. There are no nuts and bolts that need replacement. In PRVs its often unnecessary to replace bearings or grind cranks, the pistons in evenfires are quite robust, the top ring is lower down the piston and so is less susceptible to damage from detonation. Mill the tops off the pistons to reduce comp, 8 to 1 is a bit low with EFI and a knock sensor. Yes, do hone the sleeves and replace the piston rings. I use ďtotal SealĒ Gapless rings. Because of the cam oiling issues absolute cleanliness is necessary at assembly.
    The actual result you will get will not be in direct proportion to how much you spend on parts, it will come from attention to detail in the overall process of the conversion.
    I await the next carefully thought out poser.
    OddfireV6
    504 V6 24V, 203
    May 2004
    Sydernee
    200
    i have paid for the engine, will be picking it up tomorrow.. i'm quite pleased with it. youre right, i dont like the idea of burning cash, i dont have enough of it :S
    as for the turbo, its a T3 Turbo .42 .48 (Stage III) brand new, in the box, and is approx 250 dollars. i figured i might give it a go, but if its too big, then its too big and i'll look for something smaller...
    as for trim size/exhaust housing, i have no idea... like i said before, im completely new to turbos, so any help will be appreciated, i dont even know my basics with turbos really...
    also, i spotted a turbo on a 760 4 cyl at my local wrecker, and he wants 150 for it.. it seems to be ok.
    i'm looking into finding somewhere for cheap gaskets, but so far, no luck... i have a mate who works at an acl distribution centre in auburn, sydney, so i should be able to get the rings through him.
    lowering the cr. how much is the question i guess...
    will post photos of the engine as soon as i get my hands on it. have already seen it, there are no obvious signs of head corrosion as far as i can see, though theres the token coagulated oil around the sump gasket...
    finally, is it a big job to turbo the sucker? or would i be best off sticking to cams and tune the computer? ideally, id like to keep the amount i spend on the engine as little as possible, but keeping it under 3 grand as a max. (ie, about 2400 taking out the cost of the engine)...
    this has been a less thought about post, as im in a tad bit of a rush today, and just wanted to answer your questions.
    thanks all
    Janek
    Guru davemcbean's Avatar
    Apr 2001
    Camden NSW & Selwyn NZ
    2,334
    Is it going to be your daily driver (i.e. do you have another car)?
    The more mods you do, the more time you need to toy with the set-up and the more time off the road.
    As OddfireV6 indicated, the quality of the outcome is proportional to the time and effort put into it, more than anything else. Obviously there's less effort involved with a naturally aspirated set-up, but if the car is not your everday driving car, then you've got more time to spend to do a good job of a wilder set-up (i.e. you don't have to have the car ready to drive again by every monday morning).
    Dave
    NZ Fleet
    1976 504 Ti
    1984 205 GT twin carb
    1991 205 SI 1.6GTI motor
    1994 106 Xsi
    1996 Mondeo V6
    Aus Fleet
    1955 203C
    May 2004
    Sydernee
    200
    dave
    its a bit of a yes and no there... at the moment ive got a crappy little mazda to get me around, so i'd like the pug to be my daily driver. atm my mazda has spent about 20% of its registered time off the road for repairs, and i hardly think it'd be more with the v6 pug.
    i aim to have the car completed my april next year (when rego expires on the mazda). the pug has been on stilts for a good few months as it is, so i do want to get it done properly.
    ideally, i guess its a balance of performance and durability i'm after, so i figure that the 7ish months left of rego will be enough time to complete it, and have it done well enough for it not to break easily (at least not like the mazda... ive spent 1500 minimum keeping it roadworthy...)
    9,185
    Janek, You've taken on a very big job, as I said just get the thing going in standard form, you will be more than happy with the result.
    No one really knows how to modify one of these yet, by the time you are ready for more power there will be a lot more information avaiable. Have you sorted out the clutch you will be using? No one has yet come up with a satisfactory solution for this.
    Graham Wallis
    dave
    ideally, i guess its a balance of performance and durability i'm after, so i figure that the 7ish months left of rego will be enough time to complete it, and have it done well Janek enough for it not to break easily (at least not like the mazda... ive spent 1500 minimum keeping it roadworthy...)
    May 2004
    Sydernee
    200
    atm it will be auto till i can figure out the clutch situation...
    Administrator
    mistareno's Avatar
    Nov 2002
    4,926
    I'm told the reason you shouldn't machine a dourvin head is because the camshaft runs directly on the head surface and if the head is warped and gets remachined, the cam bores will be aout of alignment and you will destroy the camshaft runs.
    If the head is not warped and is just being skimed to change compression ratios, I would think it would be okay...
    Just a long shot, but what is the bore diameter on a PRV V6???.... I don't suppose Dourvin 4 pistons from a Fuego would fit?
    Aus spec Fuegos only run about an 8.5:1 C/R ....
    Apr 2001
    2,334
    Quote Originally Posted by mistareno
    Just a long shot, but what is the bore diameter on a PRV V6???.... I don't suppose Dourvin 4 pistons from a Fuego would fit?...
    The 2664cc V6 has the same diameter pistons (88mm) as the Fuego, so yes they may be the same. It would make sense, since they're made in the same factory and if I'm not mistaken they share rocker arms. Somebody will hopefully know the answer to this.
    The 2849cc has 91mm pistons and the 2975cc has 93mm pistons.
    Dave
    NZ Fleet
    1976 504 Ti
    1994 106 Xsi
    1996 Mondeo V6
    Aus Fleet
    1955 203C
    Apr 2001
    2,334
    OK, if you want to get it to daily driver standard within 7 months then DON'T muck around with a turbo.
    You're going to have your work cut out for you as it is doing everything to a decent standard in that time. This is assuming you work or study 4 or 5 days a week.
    Dave
    NZ Fleet
    1976 504 Ti
    1994 106 Xsi
    1996 Mondeo V6
    Aus Fleet
    1955 203C
    Dec 2002
    211
    What made you decide not to go with the SR20? Oh well, good luck with the V6. A new T3 for $250? If you decide not to buy it could you PM me with sellers contact details? It may be a good upgrade for the SR. May I suggest 2 Nissan GTR T25 turbos as they are perfect for a medium boosted 2.6 litre and they should be quite cheap as alot of the GTR boys ditch them for bigger ones. Also for mild to medium boost 8:1 is a bit low - the SR uses 8.5:1 which is fine for all but huge boost levels...assuming you go the turbo route that is.
    152
    New T3s for $250? I find this unbelievable, are you sure about this, if they are I'll have half a dozen for later. Can I also have the details please.
    OddfireV6
    504 V6 24V, 203
    May 2004
    Sydernee
    200
    oddfire, the trubos are in the us, on ebay. his reserve is about 200 dollars, ill send you the link a bit later. theyre master power brand or some such.. its +50 fos shipping approx, and they dont get bidded on very much. so for around 250 us, you have a brand new t3, hence my consideration of a brand new turbine.
    i'm picking up the engine today. i got it wrong, its a 1990 model i'm pretty pleased with the buy
    dave, i have to say, i pretty much agree with you. i do study 5 days, and work part time about 30 hrs a week, so until november, i dont have much time, but then i'm on holidays
    nisspug, the sheeer price factor is what made me reconsider. i would love to have an SR powerplant under the hood, but maybe at a later stage, on my other 504, when i have a tad bit more cash.
    will be posting photos today or tomorrow.
    http://cgi.ebay.com/ebaymotors/ws/eB...tem=7917094046
    is the link for one of the turbos. he has several more for sale, and a range of sizes too.
    cheers
    -Janek
    P.S. thanks for your input everyone!
    9,185
    cheers
    -Janek
    I thought T3 was a Garrett designation.
    Good price for the B280, I payed $1400 a couple of years ago, but it was in truly excellent condition.
    Graham Wallis
    12,256
    Graham Wallis
    have sandwood got a contact number at all
    i have tried emailing them a few times and never seem to get a response
    1 x '98 306 GTi6
    Dec 2002
    211
    Those "T3" turbos on ebay look super-dodgey! T3/T4 flange??? well which one? they are different flange sizes! Also .42 A/R T3 comp cover? Tiny! T28s come standard with a .60 T3 cover. Pass, me thinks.
    May 2004
    Sydernee
    200
    yeah, but i figured seeing that i only need a smallish turbo, it may have been ok... but oddfire is right... i'd be better off getting an ex skyline turbo... thats a while down the track in any case.
    but now i have started to think about transmission, seeing that the engine is underway...
    was thinking, since the prv's are all the same, why not use the flywheel off a 605 manual, i'm sure that i'd be able to find one wrecked around somewhere... i'm going to start looking at other possible fly's, but atm will source myself a 604 auto...
    photos will be going up in a few hours... the wiring harness is a MESS! but i hope its all going to be worth it. the stripping starts this weekend.
