505 extractors
Results 1 to 16 of 16
Thread: 505 extractors
    Fellow Frogger! Tiop's Avatar
    Hunter Valley
    145
    Icon6 505 extractors
    has any one here every had extractors put on their 505 ?
    Iam thinking of doing this to my 505 GTi s2 after i get it resprayed ?
    Currently has a 2inch straight through exhaust (noisy)
    If any one has done it is it worth it ?
    Ive had one quote for a set of pacemakers custom made for $600
    does any one else think thats expensive ?
    Hunter Valley
    145
    any one think it will be worth while if i can get it for a decent price ?
    any one think it will boost performance over standard ?
    Fellow Frogger! petermc505's Avatar
    Melbourne, SE
    172
    Where did you get the quote for the custom made extractors?
    would it be the same for a S1 GTi?
    $600 sounds a little steep- but what material are they made out of?
    Please let me know when(if) you do this if you notice any
    improvement in performance
    also, how much is it costing you to re-spray
    84 505 GTi - Sold to a friend... written off 3 months later
    Guru davemcbean's Avatar
    Apr 2001
    Camden NSW & Selwyn NZ
    2,334
    This exact topic is currently being discussed under the topic "Fuego X file". Check it out.
    For those who don't know, the Renault Fuego, 20, 25 and 21 (and many 18s overseas) use the same type of engine as the 505 STI and GTI.
    Dave
    NZ Fleet
    1976 504 Ti
    1984 205 GT twin carb
    1991 205 SI 1.6GTI motor
    1994 106 Xsi
    1996 Mondeo V6
    Aus Fleet
    1955 203C
    Hunter Valley
    145
    but this is my thread
    lol will do.
    um i only got one quote for respray and that is from the pin strip up it was $1300, ganna try a couple others first but they said bout $3500 for whole car.
    if i get extractor what will happen to those little copper heater pipe things that go to standard manifold what are they ?
    Gus
    Gus is offline
    Fellow Frogger! Gus's Avatar
    Jun 2002
    Canberra, Australia
    600
    The 'copper heater pipe' things is Exhaust Gas Recirculation, part of the anti-pollution. The idea is that, at idle, the engine re-chews some of it's own exhaust to reduce emissions.
    A sketchy proposition then, and a sketchier one 20 years later... my local Pug mechanic told me that some years of cars had them, but some didn't. Getting rid of it will help performance if it's broken (there's a vacuum valve which lets the gas in when it's wanted), and probably not even increase emissions by much if it's still working.
    Good luck w/ the extractors. Let us know how you go.
    Fellow Frogger! 505 to the max's Avatar
    Newcastle
    380
    Tadpole,
    I have a 505GR with GTi motor transplanted in (GR is about 120kg lighter). The mods are as follows: 10.2:1CR, bigger cam, ported, EMS computer (fuel & ignition), f/wheel lightened by about 15%, 3 angle valve grind, 4-2-1 extractors and larger exhaust (mandrel bent), K%N pod and a few cooling related alterations. To date it's best dyno readout is 115rwhp at 5700rpm. This translates to approx. 150 at the flywheel. Not a huge gain (around 30hp over standard), the ZDJL motor is long-stroke (just), so it's made for torque not huge revs so don't expect miracles from minor breathing improvements. To get huge power you would have to bore it out to reduce friction losses created by piston/cylinder contact. I would not recommend this practice as the cylinder liners will suffer reduced reliability due to less metal available to cope with the stress of combustion. The torque is quite strong however, and being a rwd pug, it's made for getting sideways.
    I'm in Newcastle if you want to see it in action.
    Fellow Frogger! crosspug's Avatar
    Nov 2001
    Newcastle, NSW, Australia
    547
    Quote Originally Posted by 505 to the max
    Tadpole,
    I think "want to see it in action" is an understatement, I've GOTTA see this
    Who, what, when and where??
    Which dyno did you get this on?? (just wondering if it was a newcastle one because I'm keen to get some "before" readings in the next couple of months and I want to know if anyone here would even know what a 505 is?)
    Jono
    BTW are you still running the standard GR suspension?? etc??
    1989 BX16Valve
    "Resting" 1983 505 STi
    Newcastle
    380
    The ECU was tuned by John Collins, owner of John Collins Dyno Tune in Broadmeadow. If you want someone to milk maximum power out of a car for you, John's the man. Darren Fullerton of Bellevue motors does any major mechanical work I need...a top bloke. Dyno figures are not 100% consistent due to fuel quality variations, ambient temps etc, so factor in a few %tolerance.
    Newcastle
    380
    Sorry I forgot about the second part of your post. Yes, unfortunately I am still running GR suspension, very 'rolly' in fast corners. It does however make it quite easy to get sideways. Body roll is not so much a problem as I recently fitted a Momo bucket seat. Not good for comfort (30mins at the wheel and I get a sore back!) but you wont come out of it in a hurry, even when you want to get out of it.
    9,185
    Tadpole,
    Just what I am about to do!
    I am starting with a standard ZDJL and megasquirt injection but will go further if results are encouraging. I do have an STI rear suspension (roll bar, springs and shockers) highly recommended and have sourced a series 2 front end.
    What revs does the car pull from and what will it rev to?
    Who did the cam for you?
    The GR is missing the vibration dampers of the STI/GTI, is it noisy?
    How is the fuel economy?
    Did you use a GTI gearbox, I will probably shorten the input shaft of my pushrod BA7/5.
    Graham Wallis
    Apr 2001
    2,334
    Tadpole,
    Cool! Would you let me post details of your motor and pictures on my 504/505 mods website:
    http://www.geocities.com/davemcbean/...l?997061496590
    There aren't alot of people in Australia who have modified the ZDJL (yet!) so my website is desperately short on examples of this. Your car would be a great addition to the website (as would Graham's rally car).
    Dave
    NZ Fleet
    1976 504 Ti
    1994 106 Xsi
    1996 Mondeo V6
    Aus Fleet
    1955 203C
    Apr 2001
    2,334
    I have a 505GR with GTi motor transplanted in (GR is about 120kg lighter). .
    Actually for a series 1 GR versus a series 1 GTI, the only big differences in weight for the GTI are as follows (approximately):
    -sunroof 15kg
    -power steering 10kg
    -extra insulation 10kg
    -extra fuel tank capacity 7kg
    -alloy EFI engine minus10kg
    The weight figures published in road tests and on rego papers are highly inaccurate (often because of difference in amounts of fuel in the fuel tank).
    Dave
    NZ Fleet
    1976 504 Ti
    1994 106 Xsi
    1996 Mondeo V6
    Aus Fleet
    1955 203C
    1000+ Posts bowie's Avatar
    Aug 2002
    Sydney, Concord City, Sir.
    3,376
    pugs made for going sideways.. hihih they dont need much coaxing with the torqu they have to get it to dance a silly song..
    My eyes lights up with glee when i have to turn 90 degree's at a intersection in the wet.. 2nd gear with 2k revs and she'll gladly step out..
    Em keen to see this moified GTI donk tho..
    Nov 2001
    547
    Alright so when are the newy boys going to get together and have a looksy?? if you don't mind 5052dMAX.....
    Jono
    1989 BX16Valve
    Newcastle
    380
    G'day all,
    sorry for the delayed response. Here are some answers for the technical questions: the cam I am running is from a Fuego clubsprint/ hillclimb car, unfortunately the lift and duration specs are unknown. It starts to pull noticably from about 2800rpm and levels off at about 5800. If it's any help I got it second hand from French Connection in Melbourne so they may know more about it. At the moment it's using a standard (Valeo)clutch with a BA7 5 speed from an STi. I can proudly say that it well and truly fried the old one which I got with the STi 'parts donor'. Due to the reliance on higher rpm I had 3mm valve shims fitted to prevent any chance of valve bounce. Due to a love of torque and pugs I have decided to fit a Garrett T28 in the near future. To spool up the turbo as quickly as possible I will be reverting to the standard GTi cam. If anyone wants the 'hotter' cam and heat wrapped 4-2-1 extractors (1 3/4 in. primaries and 2 in. collectors) then track me down through Pug Club NSW or E-mail me at [email protected] . Dave, as soon as I get my camera back I'll more than happily send photos of my car to you.
